Data Loggers
Old May 26, 2010 | 02:29 PM
  #551
truckin151's Avatar
truckin151
If SC does it then I will swap back to it. Just cant afford to do it till they get it all worked out otherwise my truck wont run
Old May 26, 2010 | 04:53 PM
  #552
RedTruck-VA's Avatar
RedTruck-VA
Originally Posted by truckin151
Honestly man, I would really back everything back to where the canned tune was until that wideband gets in there. Going at it blind can hurt ya bad
Truckin, Thanks for the input. I played with it and couldn't get it where I wanted it, went to the 93 canned tune and still had knock. Ended up using the 91 canned tune. I use 93 octane but apparently it wasn't enough to run the 93 tune. Don't know... The AI really is a great setup.
Old May 26, 2010 | 07:45 PM
  #553
03MopaRamman's Avatar
03MopaRamman
Interesting discussion Guys, Like i said before I can't wait to be able to spin my tires and with that driving high above sea level (solution is save some money= buy gears= 5 second range data log times and tire spin??).
Old May 26, 2010 | 07:58 PM
  #554
RedTruck-VA
Have you done the the TMR mod? That'll let you spin your tires. Do the search in DIY section for details and it's free.
Update: I didn't see the TMR mod listed in your signature before. You should be able to spin them now, not that spining tire is a sign of anything other than poor traction.
Old May 26, 2010 | 11:20 PM
  #555
03MopaRamman
Yep-TMR Mod (listed as TMR Del), No I can't spin them at all from a straight line WOT start. But as you know logged 6.59 running my 3.55 One wheel wonder. I attribute that to the great traction of my wide pro-comp tires. With some stock tires who knows. I remember when I was stock I could smoke them on a cranked wheel with the P265/70's.
So that said if its rained or icy I can get in alot of trouble fast. I can't wait to break loose (i'm on the edge now) and have plenty of patience to wait for my DTT and 4.56's mods I have planned. i will however do the Torque converter first though as i should be able to afford that later in the fall and am curious if the 30% more torque to the wheels that TCI claims is true. yep I'm going with that one as my tranny is old and I can get it for approx $425 CAD delivered to my door and can certainly handle the install.
Old May 27, 2010 | 09:47 AM
  #556
SilverBullet08's Avatar
SilverBullet08
i truck club just got a performance shop as a sponsor. i can do 3 pulls for 60 bucks on the dyno and get my tb ported for 100!! thats def. getting done next week
Old May 27, 2010 | 09:58 AM
  #557
truckin151's Avatar
truckin151
Nice, lets see what your truck can do now
Old May 27, 2010 | 10:00 AM
  #558
SilverBullet08
im gonna wait a little bit on the dyno but im def. get the tb done...
Old May 27, 2010 | 10:23 AM
  #559
Off_Road_Teacher's Avatar
Off_Road_Teacher
What kind of numbers do you think your truck will put down?
Old May 27, 2010 | 11:04 AM
  #560
SilverBullet08
275-280hp 300tq... i want to use this gas up and then go on the 91 tune before i do the dyno though...
