Bed Liner
Old 08-04-2010, 04:00 PM
pjordan4477's Avatar
pjordan4477
pjordan4477 is offline
Question Bed Liner
Has anyone used that Herculiner roll on stuff?
I want a bedliner (spray or roll) before I have the 5th wheel hitch installed.
I'm all about DIY when the product is quality.
Old 08-04-2010, 10:20 PM
badblackram06's Avatar
badblackram06
badblackram06 is offline
Herculiner is a cheap DIY. I spray bedliners for a living and i cant begin tell you how many Herculiners i've had to scrape off and re-spray with our spray on bedliner. The thing is Herculiner can be a good bedliner if done right. Its all in the prep job. Sanding and cleaning the surface are the top most important things. Also any moisture present while applying the liner will bite you in the butt sooner or later.
Old 08-05-2010, 01:10 PM
pjordan4477
So clean, sand, clean again, dry then apply...
What does spray in cost. I know the gallon of Herculiner is $90 (if one gallon isn't enough then I'd pay $300 for the spray).
Old 08-05-2010, 07:50 PM
badblackram06
we charge 400 for an under the rail and 450 over the rail. 1 gallon may not be enough. We spray around 3.5 gallons for an under the rail. I usually spray it 1/8 to 1/4 inch thick
Old 08-06-2010, 10:50 AM
pjordan4477
Math:
3.5 = 4gallons at $90 = $360.00
Over rail is what I want, that's $450 so would save $90 for my time....without a warranty of any kind...
I don't think Herculiner is the way to go.
Awesome, thanks for the info.
Old 08-07-2010, 02:21 AM
casper3380's Avatar
casper3380
casper3380 is offline
id pay, like i did, for a name brand, and get the warranty. could be a major issue if you happen to have to do it again. being only a difference of 90 bucks, i say get it professional. not sure bout the herculiner, but you can get pro spray pretty close to a perfect match for nothing, atleast where i live,lol.
Old 08-07-2010, 10:22 AM
chevyguy1973's Avatar
chevyguy1973
chevyguy1973 is offline
Herculiner is good stuff for the right application as long as you have the patience. I've covered the front and back bumpers, the grill, and tool box on my truck with it. Key is in the prep work as stated.
Having said that, I've got a professionally sprayed bed liner. That's just too big of a work area that takes too much abuse and is too easy to screw up.
Old 09-15-2010, 05:20 PM
pjordan4477
I have an over the rail Rhino Lining appt for 9/20 - $400. They will also be tiniting my front windows to match the stock back windows - $60.
Old 09-20-2010, 10:58 AM
pjordan4477
On 9/14 I found out I'm having twins.
Bed liner - CANCELED.
Window Tint - Still On.
Old 09-20-2010, 11:29 AM
cjs4444's Avatar
cjs4444
cjs4444 is offline
Anyone heard of SEM bedliner?
Quick Reply: Bed Liner
