Old Aug 17, 2015, 01:16 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Fuel System Guides
Print Wikipost
getting poor gas mileage on a hemi
Old Sep 10, 2015 | 12:43 AM
  #51
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
31,000 miles in 12 years? That truck has been sitting a lot. Low miles always sounds good, but in reality it really is NOT good for the parts that count on the circulation of fluids to keep them clean and/or pliable.
Have you tried hooking it up to a reader that can extract more than just generic codes?
*EDIT* It IS a sharp looking truck...
Old Sep 11, 2015 | 01:06 PM
  #52
smicksjohn's Avatar
smicksjohn
the trucks check engine light isn't on. would it still show error codes, thanks for complements.
Old Sep 11, 2015 | 05:09 PM
  #53
HammerZ71's Avatar
HammerZ71
I'd say it's in need of a tune up. My old '04 Hemi 4x4 averaged just shy of 13 mpg in all around use with 4" of lift, a ton of power mods and with winch, full boxed sub frame and gear topped the landfill scale at just shy of 7000 lbs. Still could manage 16 mpg on trips if I wasn't towing. That's about what my '02 Chevy 5.3 did stock WITH 100 LESS HP.
But I was meticulous about upkeep and used all synthetic fluids...
Old Jul 16, 2016 | 02:55 PM
  #54
stev's Avatar
stev
I had read about the "ground the TB" mod sticky. Some say it helps with mpg and others say no difference. Those that have benefits tend to use a thicker gauge wire.
The benefit is better pedal response, thus better ability to control your foot when getting into it.
I do find that keeping the pedal pressed to show RPMs around 1500 tends to be a sweet spot, but it depends on road conditions and location.
Our Rams also have different rear axle types. The 3.73 is a little better than the gen-2 having the 3.92. My problem is, I went from a 5.2L to the 5.7L HEMI. Thus, the rear axle benefit for comparison is abut the same for mpg.
Old Aug 4, 2016 | 09:18 PM
  #55
davb673's Avatar
davb673
Originally Posted by Marx
also don't go by the overhead its really not that accurate, and it could be that it originally had 17" rims on and now its got 20"'s making it even more inaccurate
my 05 with 20's gets about 12 city and 16 hwy, if i drive like grandpa i can get 13city and 20 hwy, but the way i drive i get about 10 city and 12 hwy lol
My overhead is about 1mpg optimistic, most of the time. I don't have a hemi, but I'm doing good to get over 11mpg city. Doesn't matter what I do. I never got the EPA's rated 17mpg highway (unless I drafted someone) until I started working on the truck's aerodynamics. My truck's OEM sticker said 14 city, 19 highway! HA!
@smicksjohn, you may need to take that truck down a country road, drop the hammer...and blow out some cobwebs. Weedahoe gave you a good list. Sharp truck, by the way.
I'd be surprised if the TB ground wire helped mpg; throttle response sure. My wife's Avenger has one. Off idle response is noticeably better.
Old Feb 8, 2017 | 10:44 PM
  #56
OCEANFILMS's Avatar
OCEANFILMS
I have a 2007 Ram Mega Cab 1500. Stock everything except K&N Air Filter, just turned 120,000 miles and I'm averaging literally about 7 MPG in the city, which really confuses me because I have a very light foot. I'd love some help figuring out why mine is so damn low when I'm reading all you guys are averaging between 12 and 14 in the city.
Old Mar 12, 2017 | 11:52 AM
  #57
Parkflooring's Avatar
Parkflooring
Default Im installing reman engine after original bottom end threw a rod
If the bottom end blows up do i need a new intake manifold. Im seeing alot of videos showing valve seats in manifold but if mine doesent have that problem can i clean dust and debris out of it and reuse it on my reman engine
Old Jun 19, 2024 | 07:26 PM
  #58
Adam Nevrumind's Avatar
Adam Nevrumind
Originally Posted by Napalm
I think my truck gets worse gas mileage than any Hemi i've seen haha.
10 city 12-14 highway
Its a 2003 4x4 Hemi with a 4" lift and 35" Tires... It's been that ****ty since I bought it two years ago. I just thought it was one of the Hemi 'features'
Nope. I win hands down for ****ty mileage. In town I'm only getting 6 - 8 mpg and when I bought it that was where it was at. It does have 200,xxx and rolls on 20" rims, but I wasn't expecting economy realistically anyways....... Lol
Old Jun 20, 2024 | 12:46 AM
  #59
Alex Medeiros's Avatar
Alex Medeiros
When I had my truck I got that kind of gas mileage because I idled it every morning during the winter to stay warm. Otherwise it would get prettly close mileage to what the sticker says.
Old Jul 10, 2024 | 04:50 PM
  #60
lxman1's Avatar
lxman1
Site Moderator
These days, my 08 Hemi Quadcab
1500 2wd, with 130k miles, with 20" wheels and factory 3.92 gears gets 13-14 in all city driving. Mixed, about 16mpg and all highway 20-22mpg. It has been close to this since day one. I have run a Diablosport Predator since it was about a month old and run the 91 octane tune with 93 octane fuel. The only mod is an Airaid MIT pipe between the TB and stock filter box with a K&N drop in filter. I also use NGK copper V-Power spark plugs instead of the oem Champions.
