2wd lift spindles...what next..?
so if I did the body lift, how do you think that would effect my extended warranty...? From what I've read the hardest thing about the body lift is the steering column extension, right? It seems straight forward, I'd probably want to try to do it myself.
And then what did you guys do about the gaps in the frame?
ohh you posted these before (or on another site)
Looks good. I am looking into buying a set pretty soon, trading my 2.5in spacer for a 2in and getting blocks or lift shackles to match it
If you look at my posts, you will see a thread on me installing the body lift. I also posted a way to easily do the steering extension. I had a few problems but figured out a free and SUPER easy fix. Knowing the fix, it will take 5 minutes to do with common hand tools
And you can either make gap guards (like I did) out of rubber mat or buy $100 OEM rear fender liners. They look good and are your best bet, I will be buying them in the near future to replace my homemade ones
