2wd lift spindles...what next..?
#51
And HERE is the proof. With pics. According to the logic used earlier, I can only assume that using STOCK 2nd gen shackles would give us considerable lift in the rear, as the drop shackle is merely a shorter-than-stock shackle that is still longer than our stock 3rd gen shackles. Make sense? I would also assume that new shocks would be required when using the stock 2nd gen piece. Discuss.
**edit**
Also good reading.
**edit**
Also good reading.
Thanks, that all makes sense now. Only problem is your first link doesn't work.
#52
