Maintenance questions
Old Jul 1, 2011 | 01:29 AM
ff2011's Avatar
ff2011
Default Maintenance questions
How do you go about cleaning your TB and what is the best injector cleaner or fuel additive to add and how often and at chris I am at ft. drum also
Old Jul 1, 2011 | 03:19 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Disconnect the electrical connector from the TB and use either a 8mm or 10mm to take out the four screws on the TB. Then use NON-CHLORINATED brake cleaner to clean the throat of the TB but nothing the outside or electronics.
FI cleaner is subject to opinions on which is best. Be sure to check out our FAQs, How To's and DIY's
Old Jul 2, 2011 | 08:49 PM
ff2011's Avatar
ff2011
ok thanks so just spary the cleaner straight in there and wipe it out with a cloth
Old Jul 2, 2011 | 09:00 PM
lxman1's Avatar
lxman1
Site Moderator
Yep, that works.
We had some bad fuel in our area a few years ago that had a high sulfur content that caused fuel sending units to fail as well as many pumps. I found that the best cleaner for fixing these sending units without removing them was the Chevron Techron in the black bottles. I have used it in my Mustang for years and never had an injector issue. I just swapped them out for larger ones not long ago and at 165K+ miles, they still worked great.
Today's fuels usually have some cleaners in them. As a rule of thumb, I usually add a bottle of Techron to the gas tank every 3K miles when I change the oil.
Old Jul 2, 2011 | 09:04 PM
MikeHTally's Avatar
MikeHTally
A Sea Foam dose often has some benefit. Don't get brake cleaner in the electrical bits. Make sure the motor assembly stays dry. If it's really grungy, it may need some toothbrush action. The backside of the butterfly will be the worst.
Old Jul 5, 2011 | 11:40 PM
ff2011's Avatar
ff2011
Ok thank yall for all the info really helpful
Old Jul 19, 2011 | 06:30 PM
Deroneill's Avatar
Deroneill
i just dropped in some FI cleaner this weekend but i havnt done it in at least 40,000 miles. Will that be sufficient or should i let the dealer do its thing too?
Old Jul 19, 2011 | 09:30 PM
lxman1's Avatar
lxman1
Site Moderator
If ya wiped it clean, then the dealer won't do any more to it. If you haven't done spark plugs in 40K, they are overdue.
Old Jul 20, 2011 | 09:18 AM
Deroneill's Avatar
Deroneill
I didn't wipe anything clean i just put fuel additive in it. And i changed the spark plugs this past weekend
Old Jul 23, 2011 | 08:21 PM
ff2011's Avatar
ff2011
Hey Lxman1 what do you mean wipe it clean
