Post pics of your Leveling kit or 2" lift with 33" or 35" tires on stock 20"s
Old Sep 29, 2011 | 11:59 PM
  #21
Brandon Anderson's Avatar
Brandon Anderson
Originally Posted by vikingdiesel
those are 35x12.50x20 but i thought that 11.5" is the widest you should go?
He was using spacers. I forget how big they were, but if I had to guess, 1-1.25".
Old Sep 30, 2011 | 12:01 AM
  #22
vikingdiesel's Avatar
vikingdiesel
will spacers create hwy wobble? Hub centric?
Old Sep 30, 2011 | 12:04 AM
  #23
Brandon Anderson
I don't know about the 4x4s, but I don't believe the 4x2s are hub-centric.
Old Sep 30, 2011 | 12:08 AM
  #24
vikingdiesel
not a fan of spacers anyways but back to this, what is the biggest/widest tire I can go with then, if I get a 2", is it the 295/65/20? I also dont want to put much trans strain on it and I do lots of highway driving with about 5-6k towing, but I would definitely want the 2" front spacer
Old Sep 30, 2011 | 12:18 AM
  #25
Brandon Anderson
I see you're 4x4, so you should look into the 2" leveling struts from Bilstein. Will bring your front up enough to use the 35x12.5s and better shocks to boot. All you would need is the wheel spacers for stock rims.
Old Sep 30, 2011 | 12:31 AM
  #26
vikingdiesel
these: http://cgi.ebay.com/ebaymotors/2-Bil...item5ae2acfa2f
Old Sep 30, 2011 | 12:37 AM
  #27
Brandon Anderson
Yessir
Old Sep 30, 2011 | 12:58 AM
  #28
vikingdiesel
so they eliminate the front springs? So its just that? Since I dont want to use spacers and I dont want the BULGE look on the tire, whats the size right under 35X12.50x20? Would it be 295/65/20?
Old Sep 30, 2011 | 01:18 AM
  #29
Brandon Anderson
No, they replace the existing struts. You won't touch the springs.
295/65R20 is 35x11.5
If you want a 12.5" tire, you look for exactly that, 35x12.5R20.
That will be the actual size as stated on the tire.
Old Sep 30, 2011 | 03:52 PM
  #30
ricer's Avatar
ricer
Try this sticky, it should answer all your questions about tire fitment:
https://dodgeforum.com/forum/3rd-gen...t=tire+fitment
