Id like to lift my truck a little more... need advise
My current setup is the 2" Bilstein 5100 leveling shock and those rear monroe shocks that raises the truck 1.5". I know the 06+ have the IFS and when you go above 2", there issues. I dont necessarily need a 6" lift, id actually be fine with another 2", so a total of 4" in the front or maybe 4.5" and ill just put a 2" block in the rear. a few questions:
1. Can i use a 2 or 2.5" spacer on top of my 2" leveling shock?
2. I found this "completer" package from HBS, is this what i need in order run higher than 2" and not have that issue everyone is talking about?
http://www.ebay.com/itm/Dodge-Ram-2-5-Leveling-Lift-Kit-Completer-Package-/110843369937?pt=Motors_Car_Truck_Parts_Accessories &fits=Make%3ADodge|Model%3ARam+1500&hash=item19cec 799d1&vxp=mtr
Gotta say Viking, I have always liked the profile of your truck, I think it looks perfect. I personally would not put one lift on top of another. I have the HBS with the completer kit although I tried to use the sway bar extension brackets and found that not using it was better. I did use the disconnects and new bushings though.
I getting rid of the wheels since I cant deal with the wobble from the spacers, I bought a nice set of Moto Metal 951's with 35.5" tires (used), even though my intention is to not use those 35.5" tires but instead just use my current 33.5" tires, im so tempted to put them on but I wouldnt mind another 2" in the front, what do you think I should do? So you have that complete package that I posted a link and the 2.5" lift, right? How is it? Any wobble?
You can't "stack" level kits, you think you have wobble now??? The only ways to go higher would be to remove what you have and buy a proper suspension lift kit OR keep what you have now and add a body lift.
BTW: who advised you NOT to get those wheel spacers? Hmmm... LOL...
http://www.topguncustomz.com/Store/G...view=256694621
on
No, you can leave in what you have now and add 3" of body lift for around $400 (assuming you install it).
The reason why suspension lifts are so high on IFS trucks compared to SFA trucks is because there is no solid axle to build off of, so it requires a sub-frame (in better more expensive kits) or a crossmember (in cheaper kits) to build off of.
More parts = more cost...
Trending Topics
There is no wobble with the completer kit, but there wouldn't be wobble without it either. It just offers stronger component parts for the sway bar that's it. When it comes to your suspension Viking, don't cheap out, its like buying a pair of shoes at payless that you plan on running a marathon in. You wouldn't do that to yourself, so why do it to your truck?
