check engine light on
Old May 28, 2012 | 08:26 PM
Five.SevenRAM's Avatar
Five.SevenRAM
Question check engine light on
hey guys, so i was getting ready to go to a family reunion on sunday when my check engine light turned on. i was around an 1/8th of a tank of gas. so i went to napa and got some lucas oil fuel treatment and put it in and put around 45 bucks in the tank. light went off as soon as i put the lucass oil in and tightened the cap down.i was thinking maybe i didnt have the cap tightened down all the way and that was causing the light to come on. but then today im driving down the road and it turned on again for no reason i could find. so i disconnected my battery and waited a bit. started it back up and no check engine light.....any ideas what that couldve been? im glad its off but kinda freaked me out cause i just bought it lol.
Old May 28, 2012 | 09:01 PM
HammerZ71's Avatar
HammerZ71
Pull the code it will be stored. Could be anything like a minor evap leak (maybe gas cap), EGR valve starting to munk up, O2 sensor starting to go, etc. No way of knowing without pulling the code...
Old May 28, 2012 | 09:03 PM
MikeHTally's Avatar
MikeHTally
Some '04s don't respond to the "key dance", but you could try it: on/off, on/off, on and write down the codes shown on the odometer. Sounds like an evaporative emissions issue. BTW, if you're in the habit of running it down that low, a CEL will be the least of your problems.
Old May 28, 2012 | 10:11 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Without a DTC code you are guessing........
Old May 29, 2012 | 09:42 AM
Five.SevenRAM
i normally dont let it go below 1/4. is there any specific reason why i shouldnt let it get down too low? jw, thanks for the tip.
Old May 29, 2012 | 09:45 AM
Five.SevenRAM
thanks guys, im going to put the computer on my truck tonight and see what it is.
weedahoe's Avatar
weedahoe
Hall of Fame Member
As you know, fuel is liquid and liquid absorbs heat. So it helps keep your pump cool
Old May 29, 2012 | 09:59 AM
Five.SevenRAM
never thought of it like that, nice to know the info. thanks.
Old May 30, 2012 | 04:34 PM
Five.SevenRAM
well i found out it was an EGR code that was throwing the CEL on. auto zone said 90 bucks for the part...anyone know where its located and how easy is the fix? thanks
Old May 30, 2012 | 04:42 PM
HammerZ71's Avatar
HammerZ71
go check what I posted in your other thread because the part AT FULL RETAIL - AT THE DEALER IS LESS!!! if you can turn a socket, you can swap the EGR out in under 10 mins. Easiest place in the world to get to...
