exhaust & MPG question
#31
#34
save gas.... yea right
There's ZERO "performance" mods or even "mpg" mods that would be beneficial to spend money on soley for the purpose of saving gasoline.
The best thing you can do is keep up on general maintenance and expect the MPG's from performance items like tuners to be a secondary bonus that would take a reeeeeeaaaallllllly long time to pay you back.
6,000lb truck = bad mpg.
catback, tuner, K&N, mod, another mod, and another mod, and another mod won't make you gain even 2mpg. Nope sorry it won't or else the dealer would have done it from the factory to save on federal emissions taxes. Your best gain will be from staying off the pedal and keeping your rpms in the 2krpm range.
mufflers and catbacks are sound purposes only.
#35
I can honestly say from 3 years experience that a better flowing exhaust will not improve mpg. I drove 80 miles a day for 5 years. I have a Magnaflow cat-back that does flow much better than stock. I gained about 12hp but is is all in the upper rpm range. I lost lowend torque whick is what you need in a heavy truck. I have a Airaid MIT pipe with a K&N drop-in filter and a Diablosport Predator. I run the 93 octane tune which returns the best mpg.
The stock exhaust nets better mpg in any configuration. usually about 1 to 1.5mpg better. Hemi's like backpressure. Even the Challenger guys complain about lost power after removing the cats and reducing the backpressure.
I currently run my Cat-back again because now I live less than 4 miles from work and am not spending $400 a month on fuel.
#37
#39
There absolutely is a mod that will increase mileage..
Install a vacuum gauge.. use it as you should..
Short version: keep as much vacuum as possible. It differs with varying mods, engines, intakes, environments, ect.. but let's say you idle at -15 inches..
Let go the brake, hit the skinny.. don't throttle any more than -5 inches.. wait for the shift.. let up on throttle a touch, keeping -5 inches.. wait for the shift.. keep same process until reaching o/d, where there will be a ton of load dropped on engine on that shift.. throttle back to cruising vacuum of no less than -12 inches...
In my truck, with my weight and overall ratio, I'm pulling 14~15mpg at -15 inches of vacuum.. the problem is holding it there... My truck averages about 14mpgs overall, and would do better if I could tolerate putting around all the time.. if you learn to drive based on engine load as represented by vacuum signal, and not traffic/speed limits, you'll be damn surprised what you can get out of these things... A $25 vacuum gauge mod is a helluva mod for saving gas..
