Long Term Storage for 2500 Questions/Help
Guys and Gals,
I am deploying with my unit for 10 months. During 7 of those months my truck will be in my garage. What should I do to help it keep? My wife is NOT interested in driving it because it is a larger vehicle than she is comfortable driving.
Here are the truck details:
2007 Quad Cab 2500, 6 speed, 5.9L
There was another thread on the 4th gen site that mentioned these as good ideas. Just want to confirm from our model group. https://dodgeforum.com/forum/4th-gen...he-winter.html
Fill the tank up with fuel and add a high end fuel stabilizer
Wash it
Do NOT set the parking brake
Etc
Is there anything else that is recommended? I am already planning on doing the above mentioned things along with an oil change. Is is really a good idea to put a full tank of fuel in it? I have heard the exact opposite.
Thanks!
Chris
Wash it
Etc
Thanks!
Chris
I'd pull the battery cable (so it doesn't discharge) and put it on stands (so the tires don't get flat spots). Sounds like it'll have to move after your deployed, which would be problematic since both of those mitigators will render the truck immovable. Backup plan would be to get the wife to take it around the block a couple times every 4 weeks or so to keep the battery charged up and the tires round. Diesel fuel isn't likely going to give you a problem.
So update to this, I am trying to acquire some stands but thanks for the note on tire inflation. I got the P2509 code this morning (ECM/PCM) thing. Most all threads I have read refer to checking all battery connections, check battery load, if needed, replace BOTH batteries.
So my follow up question is should I replace them now, before this deployment or risk it and do it after?
I am also considering replacing them and possibly getting a battery tender for it.
Again, thanks for all the help.
Trending Topics
