Not as much power as before??
Old May 16, 2007 | 07:52 PM
Max00racer's Avatar
Max00racer
Default Not as much power as before??
Before I got my diff replaced at the dealer for the old one blowing, i used to be able to redline it when doing burnouts...now I can't seem to get it past 3,500 rpm. Anybody know what could be the issue??? The gear ratio is the same because in 4x4 it doesnt bind so the gearing cant't be wrong 3.55 posi.
Old May 16, 2007 | 07:56 PM
HuntinHanson's Avatar
HuntinHanson
Default RE: Not as much power as before??
did they reset your computer or anything like that when they replaced the differential?
Old May 16, 2007 | 08:00 PM
Pappy_FB's Avatar
Pappy_FB
This is interesting..
Can you get it up passed 3500 not doing a burnout?
I meana good take off but not smoking the tires, Where is it shifting Wide Open Throttle (WOT) first to second and second to third?
Old May 16, 2007 | 08:12 PM
Max00racer's Avatar
Max00racer
ORIGINAL: Pappy_FB
Oyyea no problem getting it past 3500, it'll chipr the tires to like 2 grand then take off when i stomp on it on dry pavement. I have the SC programmer too. First to second at WOT shifts at 5800 second to third i believe is about the same or a little lower. I knew they didnt flash the computer because my rev limiter was still upped to 6grand. even with 4 people in the truck or just me 3500 it doesnt have the muscle to push it past there. I did it with 4 people in the truck and about 200 lbs in the bed and got it to about 2800-3000. Its really weird. And you would think past 3500 it would be no problem cuz thats where the power band starts kicking in. then wet pavement its no problem at all.
Old May 16, 2007 | 08:39 PM
Pappy_FB's Avatar
Pappy_FB
I'd give this a shot..
Reprogram it back to Stock settings, drive it around a bit.
Then program back to what you want.
See if that makes a difference.
Old May 16, 2007 | 09:32 PM
Max00racer's Avatar
Max00racer
I'll try that.
Old May 16, 2007 | 11:21 PM
FFMedic1479's Avatar
FFMedic1479
Return to stock with the SC, pull out the fuse for the PCM, key over a couple times till you hear a couple dings and see a the lights blink on your dash, put the fuse back in, reprogram with your SC.
Old May 17, 2007 | 01:35 AM
Max00racer's Avatar
Max00racer
had this problem before FFMedic?
Old May 17, 2007 | 10:52 AM
FFMedic1479
No, good troubleshooting method for most issues when having the SC
Old May 17, 2007 | 02:04 PM
Pappy_FB's Avatar
Pappy_FB
ORIGINAL: FFMedic1479
Good info to know FFMedic.
Just a question here.
I assumeyou turn the ignition back off before you put the fuse back in?
