Which Exhaust? Get others opinions here!!
Old Mar 27, 2008 | 08:28 PM
  #331
red06RAM's Avatar
red06RAM
Default RE: Which Exhaust? Get others opinions here!!
My stock exhaust was 3 inch in 3 inch out. When I switched to dual I went 3 inch in into dual 2.5.
Old Mar 28, 2008 | 09:18 AM
  #332
HEMI07's Avatar
HEMI07
i know that magnaflow uses their 5x8x18 oval 3 inch in / 3 inch out muffler and they sound really good.
Old Mar 28, 2008 | 01:18 PM
  #333
fish n chicks's Avatar
fish n chicks
borla forever.
Old Mar 28, 2008 | 05:45 PM
  #334
jonnymagnum's Avatar
jonnymagnum
has anyone put a magnaflow 14" muffler on the hemi? I have an 18" on my dak and its pretty loud. I just wanted to see what the 14" sounds like on a hemi. they do make an 11" too. but that might be too loud.
Old Apr 26, 2008 | 01:53 AM
  #335
Stunnerguy's Avatar
Stunnerguy
Wut would sound better. Want to either put Flowmaster 40's or super 44 on my truck.
Old May 2, 2008 | 11:28 PM
  #336
megacab19's Avatar
megacab19
Ok I know that I am going to get a ton of different opinions on this one but here goes. I am going to get a catback on my 07 Mega Cab 5.7L. I have the choice between Gibson and MagnaFlow.I want a nice tone without the interior drone. I am just wondering from those that have either of these installed and how you like them. Thanks for the help in advance.
Steve
Old May 5, 2008 | 04:39 PM
  #337
345hemiram's Avatar
345hemiram
OK, I am new to the forum. I have a 2003 Hemi Ram SC/SB 1500. I want to know what you guys think about my exhaust idea before i commit to it. I am thinking of doing long tubes to high flow cats with a 2.5" x-pipe and dual aero turbine 3030's, dumped before the rear axle. I have thought about it and I dont see any reason why I shouldn't, but i thought maybe someone more knowledgeable than myself could tell me if there would be an issue with the system i.e. not enough back pressure, better option, etc.
Old May 5, 2008 | 11:14 PM
  #338
345hemiram's Avatar
345hemiram
I am considering this as a more affordable option as opposed to purchasing the dynatech longtubes with cats and y-pipe for $1500 and a Gibson supertruck exhaust for about $450. When you do all the math for the system I described above, it comes out to a little over $1200 for the entire system. Let me know...
Old May 10, 2008 | 08:29 PM
  #339
vipersforsale's Avatar
vipersforsale
ok so I had to have the rear resonator removed since it was kinda rubbing on the hellwig sway bar I just installed, $40 later and I was pleasantly suprised and the sound difference without it. It no muffler change but it does provide a bit more of a lopey sound and when you floor it, it no longer sounds like a sewing machine as someone before me put it. But I must make a comment here about something that most of you dont really get into... the exhaust tip itslef. A tip alone can totally change the way an exhaust sounds. A small round tip that isnt any bigger than the pipe itself will do little to the sound, but as everyone knows a 2 foot long 4 inch megaphone tip will vibrate the walls in your neighbors house down the street. So it makes sence that some of the systems that some of you are installing are being affected by the type and size of the tips you put on. I have hte factory chrome add-on tip and before the rear res was cutoff I had it basically just barely covering the ugly bare meetal part of the exhaust. But because the guy at the exhaust shop was all too careful for his $40 he just cut me an extension when bypassing the res and rewelded it all together and so the tip needed to be relocated farther out along the pipe so it would be about even with the edge of the bed like it was before. Well that action alone made a significant difference in the loudness of the exhaust note. Now that I moved the tip out and had the res cut off, I no longer see the need for me to change over to a louder muffler just because I want the sound and seeing that most mufflers change your performance little there seems to be no need for it for that either.
Old May 11, 2008 | 12:30 AM
  #340
fireaxe19946's Avatar
fireaxe19946
I removed both resinators on my 06 dodge ram 5.7 with MDS and replaced it with a Super 40 series flowmaster. it sounds awsome. My wife didnt think she would like it but even loves the sound. she said it makes it sound like it has ***** now! now i am looking to put headers on eventually any suggestions as to what brand? found some pacesetter ceramic coated for $355.00. think i should get them?
