Debadged 07 - can see outline
Old Jun 11, 2007 | 12:24 AM
KS_Hemi's Avatar
KS_Hemi
Default Debadged 07 - can see outline
Ok, just removed the RAM 1500 from the passenger door of my 07 Patriot Blue Ram and the further to the right you get, the more of an outline you can see. By the time it is in the 1500, you can clearly see the outline of where it used to be. In fact, running my fingers over it, the outline is clearly raised from the rest of the door. I used goo gone and a plastic putty knife, then stage 1 Liquid Glass paint cleaner / swirl remover to finish off.
Any ideas? It looks really bad, particularly in direct sunlight. I don't want to continue with the driver door until I figure this out.
Old Jun 11, 2007 | 12:29 AM
ray97's Avatar
ray97
Default RE: Debadged 07 - can see outline
I just debaded mine and I can see it barely only in the shade. Since mine is an 03 I expected that until it fads to match. I used the eraser wheel which was AWESOME someone on here recommended that to me and I finished it off with the 3m remover which worked really well. Other than that no other suggestions.
Old Jun 11, 2007 | 12:31 AM
HuntinHanson's Avatar
HuntinHanson
Just keep washing and waxing regularly, eventually the two colors will blend
Old Jun 11, 2007 | 12:39 AM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
ORIGINAL: HansonHVAC
yeah, what he said
Old Jun 11, 2007 | 12:54 AM
KS_Hemi's Avatar
KS_Hemi
I'm not quite as concerned about the color as I am the very raised outline of the letters. It looks like I took a clear sticker in the outline and put it on the door. I am sure there is no adhesive left though, the goo gone and liquid glass would've removed it. Would a claybar or whatever this eraser wheel is help?
Old Jun 11, 2007 | 09:54 AM
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
If there is something raised left you either pulled out the metal or you have glue left. The body is not raised under the lettering from thefactory and I doubt you pulled out the metal when you pulled off the lettering.
Old Jun 11, 2007 | 11:23 AM
blamb's Avatar
blamb
I usedPPG's DX440, you can find it in most any automotive paint supply store. I used a clean rag and just kept going over the area until there was nothing noticable as I ran my finger over it. Then a good wash and wax, and i can't see anything at all.
Old Jun 11, 2007 | 11:29 AM
HuntinHanson
can you feel anything there when you rub your finger across it?
Old Jun 11, 2007 | 02:25 PM
07Ramjam's Avatar
07Ramjam
Im not trying to hijack your thread,but I have a question about debadging.
Im going to be taking off the "Big Horn Edition" on my 07,is it really safe to use Goo Gone on the paint?That stuff seems pretty strong,it wont take off the paint?
Old Jun 11, 2007 | 03:09 PM
Pappy_FB's Avatar
Pappy_FB
ORIGINAL: 07Ramjam
Nah, just don't use it indirect sun lightor if the fender is hot as it will dry very fast. Some say WD40 will do the trick as well.
