Spoke too soon dammit!!!
Old Jul 19, 2007 | 08:13 PM
Brawler's Avatar
Brawler
Default Spoke too soon dammit!!!
Knew i should have shut my mouth about the luck i had changing the rear diff fluid. Went to start the truck and now all i get is the stupid little blinky light and no engine turn over. I assume the battery has gone to poopie but i wanted to know what you all are replacing your stock batteries with? I need the bigger 750 cca one so i was thinking about a red top optima. Also, if i recall when the alt is charging the meter should read 14+ volts correct? And when the alt is not it usually reads 12+ ?
Old Jul 19, 2007 | 08:35 PM
casper3380's Avatar
casper3380
Default RE: Spoke too soon dammit!!!
optima is a good choice for a battery. The truck will register 14.4V when running and 12V when the engine is off, give or take a little bit. So you got that part correct m8. hope this helps.
casper
Old Jul 19, 2007 | 11:57 PM
Brawler's Avatar
Brawler
Went ahead and got the yellow top thats rated @ 750 cca. Hella expensive but i run one in my crawler and have always liked them. Kinda a pain in the *** to situate in the factory location. May fab up a custom mount when i get moved.
Old Jul 20, 2007 | 12:12 AM
bksram3500's Avatar
bksram3500
Don't look at it as a break down, look at it as an opportunity to upgrade.
Old Jul 20, 2007 | 12:26 AM
Brawler's Avatar
Brawler
It's funny how all the " UPGRADES " i've done lately have only come as a result of reading this forum. Glad i'm here though. Saved me a lot of money in the long run.
Old Jul 20, 2007 | 01:14 AM
dhvaughan's Avatar
dhvaughan
yeah if you do it yourself you can afford 10 times as much.
Old Jul 20, 2007 | 08:45 AM
chopperzen's Avatar
chopperzen
This place will make you do more mods too.
Old Jul 20, 2007 | 12:17 PM
John  M's Avatar
John M
ORIGINAL: bksram3500
I call that a Forced upgrade opportunity
Old Jul 20, 2007 | 02:22 PM
Brawler's Avatar
Brawler
My battery registered 13.58 volts when i tested it but it was bought off the shelf with out me pre charging it. Could the alt be going bad? Or is 13.58 acceptable?
