Hemi 5.7 Warm Up?
Old Sep 17, 2007 | 07:07 AM
njramguy's Avatar
njramguy
Default Hemi 5.7 Warm Up?
Ho long should i let my 05 RAM warm up before driving on the winter months around the corner. Its the 5.7 HEMI.
Thanks!
Old Sep 17, 2007 | 07:52 AM
#Red's Avatar
#Red
Default RE: Hemi 5.7 Warm Up?
When I lived in CT, I always let my truck warm up at least 4-5 minutes in the winter months and that was from being parked in a garage. Outside temps were always down near 5-20 degrees. This also gave me enough heat to keep the windshield clear. Back then, I had an '02 with the 4.7. Red
Old Sep 17, 2007 | 08:25 AM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
When I lived in Pa., I always would let the car warm up until the temp needle moved off the peg. As far as time, it all depends on how cold it was outside.
Old Sep 17, 2007 | 09:12 AM
Horseapples's Avatar
Horseapples
while you are warming your truck, warm your tranny too. let it idle in neutral for a minute or too, this will pump more fluid than park, warming the trans fluid.
Old Sep 17, 2007 | 11:16 AM
motorhead426's Avatar
motorhead426
ORIGINAL: L and R Two
I pretty much do the same thing. I removed my mechanical fan and installed an electric one, so mine warms up faster then before. I usually warm upplus or minus 10 minutes. That way the heated seats are plenty warm.
ORIGNAL: Horseapples
I've never heard of that. Might be worth looking into.
Old Sep 17, 2007 | 11:24 AM
Horseapples
The way it was explained to me by my tranny guy was this:
When the trans is in park, the park gear allows the pump to bypass to keep from building excess pressure during extended periods at idle. While in gear or neutral, the pump is engaged, allowing full pressure to circulate through the system.
Thats what I was told. At the drag strip, in my Demon, the trans temp drops much faster ideling in neutral than it does in park. Thats all the proof that I have that it works, but its enough to convince me.
Old Sep 17, 2007 | 03:19 PM
Nicky B's Avatar
Nicky B
Well this what I do. If its over 50degrees then I give the car 90seconds. If its over 75 then 60seconds. If between 0-50 I give it atleast 2minutes.
Old Sep 17, 2007 | 03:22 PM
HAWKDRIVER's Avatar
HAWKDRIVER
Neddle comes off the peg......drive away.
Old Sep 17, 2007 | 05:01 PM
bobbylight's Avatar
bobbylight
same here, once i tell the needle has moved off the peg
Old Sep 17, 2007 | 07:10 PM
HuntinHanson's Avatar
HuntinHanson
i'd say bout 5 minutes...
