Towing: Is my 1500 gonna handle it?
Old Oct 10, 2007 | 07:12 PM
husley's Avatar
husley
Default Towing: Is my 1500 gonna handle it?
We have a 02' 1500 Quad Cab Long Bed with the 5.9L V8.
The manual states that 8000lbs is the max towing.
We are getting a trailer that is 5000lbs and will probably be around 6000lbs when it is loaded.
We will be towing it at the most two times a month (travel trailer)
Are we going to destroy our Truck towing this Trailer?
All input is appreciated!
Thanks
Karna and Justin
Old Oct 10, 2007 | 07:19 PM
HammerZ71's Avatar
HammerZ71
Default RE: Towing: Is my 1500 gonna handle it?
Not on an everyday basis, but occasionally you should have no problems. It would not be a bad idea to have a tranny temp gauge installed, you can get a really cool setup that replaces your driver side pillar. Fairly cheap, I'm thinking maybe $200for pillar & gauge.
The tranny is the one component more likely to fail during towing so monitoring the temp. would be a good safeguard. Also, servicing the rear differential and tranny fluids about twice as often as the manual calls for is another pretty good safeguard. With a lot of towing, you should also think about changing engineoil & possibly radiator fluids more often than when you didn't tow. Of course, brakes will wear out faster stopping a heavy load so just keep an eye out there too.
That should really about do it. I'll try to find a pic of that replacement pillar & gauge and possibly a link to purchase it.
Here is one for about $50.00, the actual temp gauge is probably about that much and to have someone run the wire might cost you $100 tops as it's only about a half hour job.
Old Oct 10, 2007 | 08:28 PM
MikeHTally's Avatar
MikeHTally
Does it have a tow package? A tranny cooler would be a worthwile investment. Deeper tranny pan and diff cover couldn' hoit either. Won't be cheap, but neither is a new/rebuilt tranny.
Old Oct 10, 2007 | 08:49 PM
husley's Avatar
husley
Yes on the Tow Package. I think it already has a Tranny Cooler: Is the Tranny Cooler the extra (smaller) radiator?
Old Oct 10, 2007 | 09:04 PM
HammerZ71's Avatar
HammerZ71
Yes, it is. I was going to ask about the tow package also, but seeing that you said your tow limit was 8000 lbs. I assumed you had it. Although I've assumed things before that I shouldn't have.
Old Oct 10, 2007 | 10:12 PM
marv02's Avatar
marv02
It can't hurt to put a larger Trans cooler on you can run then in one after anouther or just get one big one Summite racing is a good place to look for one just find out how much room you have to install one or replace the stock one.
Old Oct 10, 2007 | 10:14 PM
NYPANAMA42's Avatar
NYPANAMA42
Excellent question, and really good advice.. Can you guys advise, i have a 4.7 LTR V-8 and when i purchased the truck it had a tow hitch already equipped. Does this mean that i have a tow package?
tdmopar59's Avatar
tdmopar59
maybe even an e fan...
Old Oct 10, 2007 | 10:16 PM
NYPANAMA42's Avatar
NYPANAMA42
One other question also, If i decided to have the tranny cooler temperature gauge installed, who could i get to do it? Also, if a tranny cooler temperature guage is so important, why doesn't Dodge, have them installed at the factory?
Old Oct 10, 2007 | 10:21 PM
Silver Eagle's Avatar
Silver Eagle
Did your truck come with a trailer hitch? If it did you should be able to tow most anything .Ask the dealer.
[/align]
