Have failures or repairs on your 3rd Gen Ram?
Old 12-15-2007, 11:41 AM
ruffnready5's Avatar
ruffnready5
ruffnready5 is offline
Default Have failures or repairs on your 3rd Gen Ram?
Please list repairs and or part failures that you've had on your 3rg Gen. Ram pre 75,000 miles and note if it was repaired under warranty or not.
Mine:2002 QD 4X 4.7 1500on 20's
power steering hose leak
AC fan fuse
broken light overhead console
radiator
mirror recall
steering column recall
steering rack leak
rearend noise
grinding in right front wheel in a turn
3rd set of brakes
3rd set of tires
sagging right visor
Old 12-15-2007, 01:06 PM
bwhite757's Avatar
bwhite757
bwhite757 is offline
Default RE: Have failures or repairs on your 3rd Gen Ram?
7,400 Miles:
T-Stat
Driver's side mirror replaced
Both covered..
You neglected to tell us your year model...
Old 12-15-2007, 02:03 PM
motorhead426's Avatar
motorhead426
motorhead426 is offline
A 2002? That just goes to show why I never buy a first model year for anything. Always too many bugs... As for covered parts...
My heated seats went out
Steering return line leaked, replaced clamp
Headliner replaced (the trim rim for the sunroof seperated from the headliner)
I had a bearing noise, so they kindly replaced all the idlers and tensioner for me before warranty was up.
Parts that failed because I am a "mod-a-holic"...
On my third CV shaft on the drivers side (stupid torsion bar lift with longer shocks)
Note: CV joints were fine, just torn boots each time it was replaced.
Things I changed before they got too bad...
Upper ball joints @30,000 miles (installed 35's with lift kit)
lower ball joints
tie rod ends
Passenger side CV shaft (because I replaced the driver side 3 times; figuredI might as well change it when I did the ball joints)
Current mileage: 48,xxx miles
regret any mods? NO WAY!
Old 12-15-2007, 05:58 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
I have not had a single repair done so far. 38,000 miles on my '04 QCSB Hemi 4x4. But I have done a lot of mods that may have gotten rid of some parts before they had a chance to fail...
Old 12-15-2007, 06:19 PM
JD1500's Avatar
JD1500
JD1500 is offline
30k
New tie rods, warranty
New front shocks, warranty
Computer update/reflash warranty.
Old 12-15-2007, 06:39 PM
CarGuyOhio's Avatar
CarGuyOhio
CarGuyOhio is offline
05 with 21K
Door seals (warranty) it is a TSB.
That is it. Anything else was standard maintenance or upgrades
Old 12-15-2007, 06:44 PM
oefootball_70's Avatar
oefootball_70
oefootball_70 is offline
Nothing, my driver seat is messed up and wont recline, but I haven't gotten it fixed.
Old 12-15-2007, 08:05 PM
cyclone429's Avatar
cyclone429
cyclone429 is offline
Cruse control ( N. safety switch ) warenty
noisey front suspension on ocassion ( 2500 ram ) dealer can never find the problem.
That is all, 06 2500 ram 5.7 6sp, 35,000 Km ( est 20,000 miles )
Most impressed with the mecanical build quality, but in researching the 1500 Ram, LSD and dodge automatics, cv joints basicly put me into a 2500.
My last 04 F-150 was close to being rebuit twice on warenty with the same mileage.
Problem I have found with Ford and GM and Dodge is that the old school 1500's were a better truck, but less car like, now the new 1500's have lost the truck strengths and adapted car qualities.
Old 12-15-2007, 10:40 PM
ray97's Avatar
ray97
ray97 is offline
Crack in the dashboard with only 38K on it.
Old 12-16-2007, 12:06 AM
KRZY.BMET's Avatar
KRZY.BMET
KRZY.BMET is offline
Peaceful Browser
Tranny solenoid at 1000 miles. Warranty repair. that is it. Truck now has 17k miles on it.
Quick Reply: Have failures or repairs on your 3rd Gen Ram?
