Driving in Tow/Haul mode
Old 02-21-2008, 01:20 PM
anton's Avatar
anton
anton is offline
Default Driving in Tow/Haul mode
Well, I'm fed up with the normal shifting points. I'll be in traffic, going about 30-40 and the trany shifts into 5th gear!! Unless you mash the gas pedal, you're not going anywhere. So, I tried driving w/ the Overdrive off but then it never shifts into 4th. I've found that driving in Tow/Haul mode allows for more aggressive shifting, while shifting into all of the gears according to a predetermined speed; which usually is right around were I would shift If it were a manual....Im happy with this but my question.....Is it alright to drive in Tow/Haul mode all of the time? Besides the little cut in MPG, is there anything I should be worried about??
Old 02-21-2008, 01:22 PM
derricksmash's Avatar
derricksmash
derricksmash is offline
V6 Ram Moderator
Default RE: Driving in Tow/Haul mode
i don't think there's anything to worry about at all. but i did say "i don't think"...
Old 02-21-2008, 03:18 PM
#Red's Avatar
#Red
#Red is offline
You're driving in traffic and the tranny thinks it's pulling a load. No big deal as long as you don't mind less MPG. Red
Old 02-21-2008, 03:37 PM
JD1500's Avatar
JD1500
JD1500 is offline
I drive around in tow/haul all the time in town. Less mpg, but 34k so far and no problems...
Old 02-21-2008, 04:25 PM
CRMRAM's Avatar
CRMRAM
CRMRAM is offline
I only clock Tow/Haul mode when I am WOT.Usually when I am passing another driver on the freeway.I never use Tow/Haul from a stop.
Old 02-21-2008, 06:14 PM
kenihemi's Avatar
kenihemi
kenihemi is offline
No problem driving with it except for the mpg like you said.
When you are just cruising on the highways, just hit the button for a spell.
Old 02-21-2008, 08:16 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
SeVeReDiStOrTiOn is offline
I drive in O/D off all the time as long as I stay under 50ish...the truck drives 100x better and the MDS stays off. Tow/Haul holds the shifts too long forme..
Old 02-21-2008, 08:20 PM
masshole's Avatar
masshole
masshole is offline
I like to use that option when I'm feeling "froggy" and want some more pep!
Old 02-21-2008, 10:04 PM
John  M's Avatar
John M
John  M is offline
The Chevy guys call it the "Tow / Haul ***" mode. The company just shortens it to fit on the shifter[8D]
Old 02-21-2008, 10:13 PM
Redram05baby's Avatar
Redram05baby
Redram05baby is offline
I Am The Same Way...
Jet Claims They Help With That Exact Shifting Issue.
Quick Reply: Driving in Tow/Haul mode
