Which oil is better?
RE: Which oil is better?
ORIGINAL: hardtufind
Is Mobil 1any good?
Does it compare to Royal Purple?
Is Mobil 1any good?
This has been hashed out before in great detail.....Use the search feature and you will have your answers.
Before you get your ***** broken for posting without searching, when looking at an oil, two main things to compare, its flash point temp (higher the better), and the ball bearing wear test (least mm change the better) compare amsoil to any oils. I've got a poll out about how long between oil changes.
Trending Topics
basics of oil everyone should know:
http://web.archive.org/web/200402021...org/motor.html
http://www.machinerylubrication.com/...20and%20Trends
testing of used oil as done by pro's
http://www.forconstructionpros.com/p...g-You/2FCP4429
the main professional magazine:
http://www.practicingoilanalysis.com/default.asp
ORIGINAL: HEMIHORN
thanks RamItOne. My dealership uses motorcraft.............(Not a huge fan but an earlier post said it was ok)
I will check it out more based on your input
I use amsoil oil that's rated at 25k miles, they sell a 7500 mile oil as well.
