stupid HVAC blend door problem
Old Mar 15, 2008 | 03:33 PM
PyRoHAvoC's Avatar
PyRoHAvoC
Default stupid HVAC blend door problem
who's had it and how much did you pay to fix it?? or if you did it yourself how did you do it?? i tore apart my dash the other day and it looks like all the actuators move the way they're supposed to but the air still isn't being routed correctly ... help please
Old Mar 15, 2008 | 03:42 PM
derricksmash's Avatar
derricksmash
V6 Ram Moderator
Default RE: stupid HVAC blend door problem
do you have a vacuum pump?
just disconnect all the vaccum hoses to you, and see if they hold a vacuum. maybe there's just a hose that popped off or something.
Old Mar 15, 2008 | 03:47 PM
PyRoHAvoC's Avatar
PyRoHAvoC
ORIGINAL: derricksmash
can you explain that a little better??
i get vent air from the passenger vents and ac from the drivers vents ... and it's exactly like that whether the thermostat is set to hot or cold
Old Mar 15, 2008 | 04:42 PM
chadmech28's Avatar
chadmech28
You blend door is broken inside the box you will have to remove the box to take the blend doors, then you will see where it's broken.
Old Mar 15, 2008 | 06:36 PM
HammerZ71's Avatar
HammerZ71
Had to replace the blend & recirc doors in my Grand Cherokee in October. What a friggin' bitch, but nine hours spread over my two days off beat the hell out of the $1100 in labor the dealer wanted to replace barely over $100 in parts...
Old Mar 15, 2008 | 10:11 PM
Parts/Service's Avatar
Parts/Service
The most common problen is number 4 in the pic below. The part that you need to fix it is about $40.00. You have to take the dash and A/C housing out of the truck
Old Mar 16, 2008 | 08:22 AM
chadmech28's Avatar
chadmech28
# number 4 is the recic door this won't make it blow cold on the driver side. You can just remove the glove box and see if the recic door is broken.
Old Mar 16, 2008 | 12:29 PM
PyRoHAvoC's Avatar
PyRoHAvoC
ORIGINAL: chadmech28
it's not ... i've had it apart already ... just wasn't sure how much more of the dash i would have to disassemble before i could take the whole box out and see what's broken ... but that's a question for someone who'se already done it ... so speak up guys ... how far do i have to go to be able to get the box out?
Old Mar 16, 2008 | 01:50 PM
chadmech28's Avatar
chadmech28
I have done these dashes before. They are very easy to do, you mush pull back the entire dash, discharge A/C system and remove box. then dissasemble it to find the broken door. I can do the entire job in about 3 Hours. Like I said before it's a broken blend door. you will need part number 3, on the pic.
Old Mar 16, 2008 | 03:38 PM
PyRoHAvoC's Avatar
PyRoHAvoC
instrument cluster air bags and the whole nine??? what's involved with discharging the system and recharging it?
