Lift and Tires
Old Mar 19, 2008 | 06:53 PM
RedRam2005's Avatar
RedRam2005
Default Lift and Tires
I am thinking about doing a lift and new tires soon to my 05 QC 4x4 ram 1500. I have narrowed it down to two options. I am thinking about keeping the stock 17x8 rims on my truck too. I want to do either a 4in rough country lift with 35x12.5x17 toyo m/t's or go with the 5in rough country lift and stuff 37x13.5x17 toyo m/t's in there. The question is would I be able to mount those onto a stock rim safely of am I basically forced into a 17x9 rim? I want to save the extra money to go with 4.56 gears if I go with 37's because I will need them with the 4.7. Either way it will be a sweet looking set up though.
Old Mar 19, 2008 | 07:16 PM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: Lift and Tires
8" rim is really to small for a 12.5" tire, get a 9" at a min or go with 10.5" tires.
Old Mar 19, 2008 | 07:19 PM
SWOS Chief's Avatar
SWOS Chief
I agree. I wish I would have went to 10.5 when I bought mine. My plan is when the set I have on die I want to move up to the 37x14.5x17 Pit Bulls. I don't think I can with the 17x9's I bought though.
Old Mar 19, 2008 | 07:27 PM
CRMRAM's Avatar
CRMRAM
Just get the 5" lift with 35's.You wont hurt your truck as much and you can still roll with it and upgrade tires later.Meanwhile you can upgrade the gearing and not spend so much money at one time.
Old Mar 19, 2008 | 09:10 PM
RedRam2005's Avatar
RedRam2005
I think I am just going to go with the 35x12.5x17 on just a 4in lift, but that is still down the road. I just bought the truck and it has new285x70x17 Khumo all terrains that ride really nice. But I just ordered D.O.R flowmaster's with a 40 series muffler. Then in 2 months I am going to get a throttle body spacer and Volent cold air intake. Then for christmas it will be headers and a newmagnaflow cat converter. Then 206 cams. The lift and tires are 3 years or so down the road. After all I am 18 and I just bought my ram and am paying for everything on it and for my college. All I cansay is that I am proud to be the owner of my 05 QC 4x4 ram.I was thinking about an 04 F150, but that would have been a mistake. I love everything about my ram. I like the 4.7 in it too. Alot of power for a small engine but not as much as in a hemi...but alotbetter milage than a hemi. lol
Old Mar 19, 2008 | 09:17 PM
HammerZ71's Avatar
HammerZ71
37's require a FULL 6" of lift to fit without major cutting. You want 35's anyway on a 1500, too many people going through too many front ends with 37" & larger tires. 12.5" tires should be mounted on 9" wheels minimum. And lastly, you are still gonna want 4.56 gears with 35" tires with a 4.7. I wasn't happy with the sluggishness of 35's with my Hemi and stock 3.92 gears...
Old Mar 19, 2008 | 09:21 PM
RedRam2005's Avatar
RedRam2005
Yeah I though about it and don't need the 37's. 35's will be plenty enough on a 4in lift and toyo mt's look mean on a truck. But I will still want the gears. Hammer... Did you do both axles at once or just the rear at first and the the front later?
Old Mar 19, 2008 | 09:35 PM
HammerZ71's Avatar
HammerZ71
You can do the rear only, if and ONLY IF you NEVER engage 4WD! If you have a different ratio front & rear and you put it in 4WD the flatbed dude will have to go back for yourtransfer case and othercomponents after he gets your truck loaded up...
My advice is to save up until you have the cash to do front, rear and put a good LSD in the rear at the same time...
Old Mar 19, 2008 | 09:43 PM
RedRam2005's Avatar
RedRam2005
That's what I figured. With 35x12.5 toyo mt's I have a feeling that I will be using the 4x4 alot. Thanks for the advise though. Any good places to buy those from that aren't too expensive? How much will those run on average?
Old Mar 19, 2008 | 09:53 PM
HammerZ71's Avatar
HammerZ71
The Toyo's are a great tire, the only brand I'd probably ever put on a truck besides Mickey Thompson or Dick Cepeks. They cost, but you get what you pay for.
On the gears I got mine at 4 Wheel Parts and had the Orlando Store do the install. They price matched the best deals I found online and comped the labor on the Auburn LSD install if I bought it from them at the same time. Came to just over $1400 with tax for the rear gears, front gears, master install kit, Auburn LSD, fluids & labor. Also included was a free check and lube change at 500 miles. This was about 2 years ago. You can try there, Moe's Performance, Air Ram or Randy's Ring & Pinion for prices.
This is something you are going to be better off not only leaving to someone else, but also finding someone with specific experience in gears installs. To date, this is the only mod I've not done on my truck myself and I wouldn't even contemplate trying it...
