New found problem w/ truck
You guys...suck...lol
You let me down for once! [
We got it, changed the oil pressure switch, checked the oil. Well see how it does tomorrow.
Thanks again for all of your advice!
]We got it, changed the oil pressure switch, checked the oil. Well see how it does tomorrow.
ORIGINAL: Kendra02
Okay, when its in drive, but the brakes are on, it has the rattleing sound on the passenger side, under the hood.
AND
If, I'm driving for about agood 20 mins, then stop at a stop sign, the oil gauge will drop all the way down and the siren will go off, and as soon as I start driving again, it will go back up..
WHAT GIVES!!
Any ideas to either..
AND
WHAT GIVES!!
possible causes can include stopped up oil pickup, faulty oil pump, mis installed rocker gear, mis installed cam saddle (ohc) worn main bearings or rod bearings. Or if your lucky it could be a faulty relief valve in the oil filter. Is it A new oil filter?
[IMG]local://upfiles/26683/E374BA0350D349CC98920409BB20B4C7.jpg[/IMG]
ORIGINAL: Horseapples
Cmon guys, a little mechanical common sense here. If the truck is rattleing at idle it is not the sending unit!The rattle indicates low oil pressure and the loss of pre load on the lifters.
ORIGINAL: Kendra02
AND
WHAT GIVES!!
AND
WHAT GIVES!!
You very well may have the faulty issue in your massive list of things that could be wrong. But how would you feel if you had tore down anengine to fix a problem that was 15 minutes and $30?
I wouldnt be throwing parts at it unless I knew for sure what the problem is. Even a 30.00$ sending unit can be verified with a mechanical gauge before spending money on a part.
Just my opinion, I could be wrong....
Hey, it matters not to me, its not my truck. If she wishes to throw parts at it untill the end of time it will not make a difference to me, so rock on "shotgun trouble shooting" will eventually fix the problem. If enough parts are changed, you'r bound to hit the faulty part eventually!
On another note, a bottle of Rislone is a good investment, if having the heads off broke lose some grime that is now clogging an oil passage.
http://www.barsproducts.com/100QR.htm
Okay guys, after what you guys said, my uncle said the same thing. So, I DID go buy the switch and so far..it WORKED!!
It hasnt done it once today.
The rattling, is the A/C compressor, my dad thinks its about to go out, so, hes going to start looking for another one.
