Trans question
Old Jun 22, 2008 | 04:06 PM
Ironhead's Avatar
Ironhead
Default Trans question
Driving on the sand last weekend and got stuck a little. Instead if airing down the tires I tried to drive out of it. Anyway, the trans light goes on and fluid starts coming out of the fill tube. I put in in neutral and keep the rmps up until the light goes out, air down the tires and I'm on my way. Did I do any damage to the trans? Is the fluid in need of repalcement?
Old Jun 22, 2008 | 07:34 PM
lxman1's Avatar
lxman1
Site Moderator
Default RE: Trans question
It overheated. I would change the fluid if ti was me.
Old Jun 22, 2008 | 08:41 PM
stratusguy02's Avatar
stratusguy02
At least check the level and ensure it is properly filled.
Old Jun 22, 2008 | 09:10 PM
Ironhead's Avatar
Ironhead
I did check the level at it was still good, didn't lose much fluid. This is a new truck with only 3000 miles on it. Do you think I need to change the fluid?
Old Jun 22, 2008 | 09:12 PM
stratusguy02
Did you lease or did you buy? If you are just leasing it, don't waste your time.
Old Jun 22, 2008 | 09:36 PM
lxman1's Avatar
lxman1
Site Moderator
If you have the lifetime powertrain warranty, I wouldn't worry about it.
Old Jun 22, 2008 | 11:51 PM
HammerZ71's Avatar
HammerZ71
Smell it. Overheated tranny fluid actually has a burnt smell to it, plus the color won't look like it did when new. If it looks like new fluid looks and smells like new fluid smells, don't worry about it...
Old Jun 23, 2008 | 12:00 AM
RamItOne's Avatar
RamItOne
first off you shouldn't need to air down the tires, well unless its 2wd and then again why buy a 2wd truck if you plan on going off road. I go down 45-60 miles if beach where the the first 2 miles is for any veh then its posted 4wd only. Never had any issues.
So how long and how hard were you reving the engine (rpms) to overheat the engine.
Old Jun 23, 2008 | 08:02 AM
stratusguy02
ORIGINAL: lxman1
+1, that is the boat that I am in. Why waste your money if they already committed to fix it.
Old Jun 23, 2008 | 09:01 AM
tigman250's Avatar
tigman250
ORIGINAL: stratusguy02
ORIGINAL: lxman1
just because they have committed to fixing it or it will soon be someone elses problem is no reason to go out of your way to break something or avoid maintenance, guys like you are the reason it's so risky to purchase from the used market.....do you roll your mileage back on your lease turn ins too?[:'(][:@]
