3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
new hear and looked for hours .....please help .... i have a 2004 ram 1500 4x4 hemi it has stock 275/60-20 tires on the factory 20" rim.
im keeping the rim and wanting to put on new cooper ltz's.
my question??? will a 305/55-20 tire fit the rim and if so will it rub in anyway.
"naked pics of my hot sister to the one with the most help" lol
thanks
It should fit......my 33x13/18 rubs SLIGHTLY only when the wheel is locked, so since you are looking at a 12" you should be fine. (**disclaimer**I am no "tire guy" though)
i hope so im trying to get coments on if they will work before i order. good deal on them 1100 to the door not to bad and i heard great things about the ltz cooper has.
anyone else know if they work maby some pics would be awesome
one shop told me 305 /55/20 will not fit on my stock 20 rim and would probably rub on the inside ...if thats true that sucks
anyone running this set up let me know
ive learned that some shops are just fcukin dumb. a guy i go to (use to) told me that there was no way in hell gonna get a 34" tire in my truck. he told me i was gonna have to grind the metal on my truck to get it to not rub....damb ***......after putting 35's on my truck.....i realized i could have got 37's in there without a problem!
yeah dude i'd say no problem....there was a guy that use to come to the delaership when i worked there that was running 315/60 i believe....he didn't have any rubbing problems, i'd say you'll be fine
thanks guys for the feed back
do you think running 305 /55 is to wide for the fender well or should i stick with the 305/50
i only like the 55 besause it it taller and wider than stock
i heard 50 is smaller than stock can you notice a big difference???
