2005 Dodge Truck
Old Jul 20, 2008 | 02:48 PM
Davidlon's Avatar
Davidlon
Junior Member
Default 2005 Dodge Truck
My AC blows cold air out the drivers side of the truck, but hot out of passengers side. I think the heater and the ac is both blowing together. Thanks
Old Jul 29, 2008 | 05:38 PM
Davidlon's Avatar
Davidlon
Junior Member
Default RE: 2005 Dodge Truck
Nobody knows anything about this problem ?
Old Jul 29, 2008 | 05:42 PM
HammerZ71's Avatar
HammerZ71
Blend/Recirc door is broken on the passenger side. About a $40 part, about $750 in labor because the entire dash has to be removed. Known Chrysler issue, I had to replace both in my '02 Grand Cherokee. Your covered if your still under your 3/36 bumper to bumper...
Old Jul 30, 2008 | 01:29 PM
WhiteRam's Avatar
WhiteRam
'Zactly what mine was doing.... heater/cooler door, only had defrost till they fixed it!
Old Aug 2, 2008 | 10:23 AM
Davidlon's Avatar
Davidlon
Junior Member
I have heat and cool at the same time. The only door I have found is closed. I have noticed that the ac when turned to regular ac and the super ac is the same. The fan does not blow any harder on the higher setting.Does anyone know where I can get a picture of the problem or a schematic ? Thanks
Old Aug 5, 2008 | 07:35 PM
Davidlon's Avatar
Davidlon
Junior Member
Anyone ?
Old Aug 6, 2008 | 09:06 PM
Davidlon's Avatar
Davidlon
Junior Member
Bump can anyone help
Old Aug 6, 2008 | 10:09 PM
lxman1's Avatar
lxman1
Site Moderator
You will need to find a factory service manual.
