drowned engine
Old Aug 3, 2008 | 04:37 PM
Ifucantdodgeitramit's Avatar
Ifucantdodgeitramit
Junior Member
Default drowned engine
I was ****ing arround in a parking lot after a severe thunder shower and there was about 3 feet of water in the lot. I was going back and forth through the water and then my truck stalled. 24 hours later my truck is still there and it does not want to start. Any ideas why
Old Aug 3, 2008 | 05:32 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: drowned engine
will it turn over? I would pull all the plugs and turn the engine over to get all the water out of the cylendars.
Old Aug 3, 2008 | 05:57 PM
mmstar23's Avatar
mmstar23
damn dude. that sucks. have no input as what to do...but that really sucks man, wish you the best on fixing it.
Old Aug 3, 2008 | 08:24 PM
brad m's Avatar
brad m
If you are not sure what you are doing this is what i would do. Pull all spark plug, drain engine oil and replace oil filter, take out air box and itake pipe and drain the water out. After the new oil is in the motor then you can crank the engine over with the plugs still out. After the water is out re-install the plugs it may not even hurt to squirt a little oil down each cylinder before you put the plugs back in. This would be a great time to put new spark plugs in also. Good luck buddy.
Old Aug 3, 2008 | 11:59 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Ouch...hydro-lock isn't fun. Don't crank it with the plugs in...water doesn't compress and you'll do some damage.
Old Aug 4, 2008 | 02:01 AM
Ben D.'s Avatar
Ben D.
lol that's what happens when u drive thru three feet of water as fast as you can......
Old Aug 4, 2008 | 02:45 AM
abarmby's Avatar
abarmby
When are people going to learn about hydro lock???
You will be EXTREMELY lucky if you havent destroyed your engine.
After all, it only takes milli secondonds for the pistons to mve up and down, find out they can't, because they cannot compress the water and then, bend rods or valves[:@]
The air box design on these trucks leaves a lot to the imagination.
This sort of "playing" shows unfortunately ignorance and inexperience. It's a very expensive mistake to make.
There are lots of posts about hydro locking on here and other forums.
Sorry for this painful lesson.
Al.
Old Aug 4, 2008 | 03:10 AM
Ben D.'s Avatar
Ben D.
exclty. altho i gotta wonder if he's exaggerating. I mean three feet of water is pretty deep. to put that in contrast that's up to the top of the tires and then sum. driving through that much as fast as you can is extremely stupid.
Old Aug 4, 2008 | 03:53 AM
Redbud66's Avatar
Redbud66
I'm sorry but I don't think that he could even get the thing to go through 3 feet of water at more than 5 miles an hour. Anyway, you might as well try to get the water out of the thing and see if it will start up...who knows it could be undamaged.
Old Aug 4, 2008 | 12:41 PM
kenihemi's Avatar
kenihemi
Even if he can drain it and start it.
He has to flush change the engine oil
trans
diffs
transfercase
they probably have vents that will allow water in
Alt is probably shot, etc.
