View Poll Results: What mode are you running your trans in when making 0-60 runs?
Trans in Normal Mode
29.41%
Trans in Tow/Haul Mode
70.59%
Voters: 17. You may not vote on this poll
What Tranny Mode For Your 0-60 Runs?
Old Nov 24, 2008 | 03:46 AM
  #31
Grey-Ghost's Avatar
Grey-Ghost
i read about everything dirtydog i go to that website to read whats going on in the truck world like i go to allpar to learn about mopar baby just because its a ford tow/haul mode is basiclly the same for all the trucks it tells what tow/haul mode does the off road mode is the samething but for off roading but changing the shift points and opening the throttlebody up the whole time is the same for tow/haul mode ok pickuptruck.com knows what their talking about man they are given the keys to all the truck makers newest models so what they same has some weight
Old Nov 24, 2008 | 06:55 AM
  #32
HankL's Avatar
HankL
it is worth asking the questions:
what rpm should my engine be at when it hits 60 mph?
should the trans shift once during the run, or twice?
how much does the torque converter slip?
how much gear ratio does a slipping torque converter provide?
to get to 60 mph as fast as possible shouldn't I be able to launch at 4200 rpm full throttle where the torque maximum is?
why can't I launch at 4200 rpm without severe wheel hop?
(hint: why does the SRT10 have modified rear springs and why does the 2009 Ram have rear coils and links?)
since I can't launch with full torque at 4200 rpm,
does having more differential ratio do anything except break the tire rubber grip loose?
Old Nov 24, 2008 | 11:10 PM
  #33
lxman1's Avatar
lxman1
Site Moderator
The torque converter won't stall to 4200 so it will not launch at 4200.
Old Nov 25, 2008 | 06:44 AM
  #34
HankL's Avatar
HankL
the torque converter will drop to its stall speed (if the tire holds traction)
but you can still launch at any rpm
with either auto trans or manual
Old Nov 25, 2008 | 08:52 PM
  #35
Grey-Ghost's Avatar
Grey-Ghost
hank L i can answer about the severe wheel hop question thats easy the srt-10 had the moded rear suspension so it could better handle the 525 ib/fts y have a 500hp truck if u can't use it at all and the new 09 rams have coilovers because dodge wanted to be different since trucks r a dying breed and a better ride also get people who would not normaly get a truck
