Gas Overflow when Full
I have an '04 Ram that has a problem at the pump, aside from being there a lot. When I fill the tank and click on the auto fill on the handle, almost simotaniously as the pump shuts off, gas shoots out of the tank back over the handle and all down the side of my truck.
I've seen a couple other threads like this and every one gets shut up with the idea that they're "doing it wrong" or it's a bad pump. Well I'm filling it the same way I've always done it with any other vehicle I've had and it's at every pump I go to, so is it the design of the truck or is something wrong maybe?
any ideas?
I appreciate your info!!
any ideas?
mine does it but not when it clicks off, it only does it if i or the gas station attendent trys to top it off, if after ir clicks off they or i put more then 50 cents it all over the side of my truck. I think it is because the filler hose is almost horizontal so when its full it is really full.. but cant be sure
+1 Mine Too!!
Trending Topics
I had the same problem with my 07 Quad cab. It's the vapor recovery system inside the tank. The dealer ordered me a new tank, replaced it in about an hour and I have had no problems since. It drove me nuts too. I tried different stations as well as pumps, I knew it was something with the truck. Hope this helps you out.
mine does the same thing. I took it to the dealer about a year ago and one of the service managers came with me to fill up. Of course its not the normal gas stations i go to, its one of the small cheapie ones. I fill up, it doesnt overfill. I noticed that the pump was going slower, so maybe that has something to do with it, but i know they didnt do a thing about it and i havent really been able to top off at a normal gas station since then. I dont know the problem, i dont know if i should just fill up slower everytime or just ask the dealer again to see if they have serviced something like it.
