I have a few problems i could use some help with....
Old Oct 28, 2008 | 01:03 PM
killerbud420's Avatar
killerbud420
Unhappy I have a few problems i could use some help with....
To start with I was checking my oil and noticed under the fill cap that it was a rusty orange color and was dripping with water. I am real worried about that because I have already lost one motor due to water in it. What could cause that? It has been running a little warmer than usual but when I turn the heater on it will cool itself back off.
The other thing I noticed in park I can rev it and it won't cut off at 4k it will just rev like any other car when you hold the gas...
Old Oct 28, 2008 | 01:13 PM
killerbud420
oh yea i smoked the **** out one of them f150 gt r or whatever the hell they are
Old Oct 28, 2008 | 01:17 PM
KrazyBrian's Avatar
KrazyBrian
What is your oil like? Milky? If so you have blown a headgasket
Old Oct 28, 2008 | 01:33 PM
killerbud420
na it looked ok...so i fully under stand when you so milky you mean as creamie or real thick lookin?
Old Oct 28, 2008 | 09:44 PM
killerbud420
anybody???
Old Oct 28, 2008 | 10:31 PM
lxman1's Avatar
lxman1
Site Moderator
Dude, fix you sig pic, it takes up most of the screen
If you do not drive the truck for long distances once in awhile, condensation will build up in the crankcase causing moisture to form in the valve covers. Short in-town trips do not get the oil hot enough to boil out any moisture accumulated in there.
Also mekr sure that your PVC system is working properly.
Old Oct 28, 2008 | 10:34 PM
6 hemi ram's Avatar
6 hemi ram
the condensation on the cap is normal. it will look rusty sometimes. as long as the dipstick doesnt look like it came out of a milkshake your fine. as far as the 4k rev limit mine will rev to 5600
Old Oct 28, 2008 | 11:11 PM
killerbud420
yea the oil looked fine im using that royal purp in there im around 1500miles on it i just hope thats alls it is...has your truck always reved up pass 4k in park mine just started
i did pull a code for the egr a while back cleared it out and it has'nt came back on hope all is good with it i been lookin at the procharger mighty hard..my bad on the sig 8 )
Old Oct 29, 2008 | 12:20 AM
lxman1's Avatar
lxman1
Site Moderator
Might have something to do with the power pup removing the rev limiter.
Old Oct 30, 2008 | 03:24 PM
Ilovemytruck's Avatar
Ilovemytruck
I replaced PCV valve and milky stuff went away on mine however, short trips all the time arent good and dont let you get rid of the condensation that builds up. If you use a superior motor oil and filter youll be more then fine, alot of dodge owners have this problem. No, it is not sludge! Good luck
