Big rear tires on 2008 2WD 1500
Old Oct 31, 2008 | 03:43 PM
MeAndMyHemi's Avatar
MeAndMyHemi
Default Big rear tires on 2008 2WD 1500
I was wondering: Back in the day we used to put big tires on the back and smaller ones on the front. My 2008 with the factory 20's needs a space filler in the rear end. If I put a 305 - 60 - 20 on the back would it screw up the ABS?
Old Oct 31, 2008 | 06:30 PM
HemiLonestar's Avatar
HemiLonestar
Well...305/50R20 hasn't screwed mine up, so you should be fine.
Old Oct 31, 2008 | 06:44 PM
nemesisprogram's Avatar
nemesisprogram
I thought of doin that also ...lol
Old Oct 31, 2008 | 07:46 PM
red06RAM's Avatar
red06RAM
Wouldn't the tires need to be the same height? You could probably put wide tires in back and skinny tires in front if they are the same overall diameter front and rear.
Old Oct 31, 2008 | 08:27 PM
jkillman's Avatar
jkillman
I would love to see this. Itll probably look like a mini dually with a super wide in the rear. I dont see a problem with doing it, post pics if you end up doin it.
Old Oct 31, 2008 | 11:06 PM
ce2flaco's Avatar
ce2flaco
In a 4X4 it could be an issue but it a 2wd with the front wheels being undriven, it should be fine.
Old Nov 1, 2008 | 12:20 AM
lxman1's Avatar
lxman1
Site Moderator
It is only a problem if you have a Laramie with 4 wheel abs. All others have rear wheel ABS so different diameters on the front and rear won't matter.
Old Nov 2, 2008 | 02:04 PM
HemiLonestar
I have the same tire size all the way round, looks great and handles better too.
