My full on system buildup
Old Dec 14, 2009 | 09:32 PM
  #71
kx250frider617's Avatar
kx250frider617
I think our truck alternators are 120 amp which is Sufficient for a mild system, around 1000 watts or tad more. Car alts need to be upgraded since they are only 90 amps. My next mod will be a kinetick AMG battery. I will post the whole install. It may take awhile for me to fab the speaker mounts.
Old Dec 15, 2009 | 12:35 AM
  #72
SilentRamAD's Avatar
SilentRamAD
What amp(s) are you running your speakers on ? I'm trying to find a bang for the buck 4channel amp so I don't have to run 2 sets of amp/rca wires seeing I'm probably going to run 4 gauge (I'd like to run 0/2g but would two sets of those run under our paneling ?).
Old Dec 15, 2009 | 12:44 AM
  #73
OklaHemi's Avatar
OklaHemi
silent ram here are pics of my crossovers and tweets installed. i have a pdx-4.100 and it has no problem at all and i dont anticipate any when i put in the pdx-1.600 because of the efficency
Old Dec 15, 2009 | 01:13 AM
  #74
SilentRamAD
Yeah I've seen your thread and read it through and through, from the looks those are the SPR-17s ? if so did it come with a flush mount tweeter kit ? I'll know soon if mine did seeing it's already in the mail along with the SPR-13c.
I swear I keep learning more and more about what I'm going to do with my audio set up. If I do end up going two varying 2channel amps instead of the PDX-4.100 I've noticed fused Distribution blocks that I'd run 0g from Bat to block and (2)4g out to amps, I'd assume that would work, seeing that's what they're meant for...bare with me as you can tell I'm a newbie to the audio world.
This is exciting and fun as all h*ll seeing how many different routes there are to do this
All in order to get the best and most suited that will please your ears.
Old Dec 15, 2009 | 01:21 PM
  #75
OklaHemi's Avatar
OklaHemi
yes spr17 and the tweets are made to be flush mounted i just cut the hole inserted the tweet and screwed the nut on the back to hold it in place. the come with some hardware to mount them a few different way but i did not need any of it. why would you use 2 amps? every channel on the pdx is adjustable
Old Dec 15, 2009 | 07:42 PM
  #76
kx250frider617
Old Dec 15, 2009 | 08:19 PM
  #77
OklaHemi's Avatar
OklaHemi
ohhhhh i just about busted a nut. i know you are happy
Old Dec 15, 2009 | 09:33 PM
  #78
kx250frider617
here are my mounts out of 3/4 mdf.
Old Dec 15, 2009 | 10:32 PM
  #79
kx250frider617
hey oklahemi.
did you ever pull the a-pillars to see if there room for a tweet. Im debating where i should install it
Old Dec 15, 2009 | 11:28 PM
  #80
Jonhyboi's Avatar
Jonhyboi
whats the other 10 for?
