fluid change??
fluid change??
allright guys im getting my boss to pay for all the fluids to be changed in my truck, so what typ of fluids should i get? and im looking at my haynes and it says to put atf in the transfercase? never had an auto 4x4, the truck is an 04 2500 QC 4x4 hemi auto, im getting the front end, rear end, transmission, and transfercase fluid changed, im also doing all of this by myself, so any tips would be helpful... thanks guys
From Amsoil's website:
2004 DODGE TRUCKS RAM 2500 HD PICKUP 5.7L 8-cyl Engine Code [D] FILTERS
Oil Filter:EAO42Absolute Efficiency Oil Filter
Oil Filter:51085WIX 51085 Oil Filter
Air Filter:EAA176Absolute Efficiency Air Filter
Air Filter:42725WIX 42725 Air Filter
Air Filter:PF8050PINJEN-AMSOIL Air Intake System
Trans Filter:58843
[1]
Trans Filter:58846
[2]
1. 4WD - Spin-on + Pan Filter Together In One Kit
2. 2WD - Spin-on + pan filter together in one kit
NGK PLUGS & WIRE SETS
Plug.................GPSERIESLZTR4AGP
[1]
Plug.................IXIRIDIUMLZTR4AIX-11NGK2313[2]
Plug.................PREMIUMPLATINUMPLZTR4A-13 *
[3]
Plug.................VPOWERLZTR4A-11NGK5306[4]
Wire Set..........WIRESETRC-CRX056NGK53020[5]
1.Twin Spark
2.Twin Spark
3.Twin Spark
4.Twin Spark
5.8 Lead Set
TRICO WIPER BLADES
Blade ClassDriverPassengerRearNEOFORMT16240
T16240
EXACTFITT241
T241
WINTERT37245
T37245
OKTANE24 inch
24 inch
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
SAE 0W-30 Synthetic Signature Series Oil
SAE 5W-30 Synthetic Motor Oil
SAE 5W-30 XL Synthetic Motor Oil
Above 0°F......10W-30
Below 100°F......5W-30[1]
Manual Transmission,NV5600.....GLS[2]
AMSOIL Synthetic Synchromesh Transmission Fluid
Manual Transmission,NV3500.....GLS[2]
Manual Transmission,NV4500.....GL-4
75W-85[3]
Synthetic Manual Transmission and Transaxle Gear Lube 75W-90
Automatic Transmission,545RFE 2WD.....AP4
Synthetic Automatic Transmission Fluid
Automatic Transmission,48RE.....AP4
Automatic Transmission,545RFE 4WD.....AP4
Differential, Front 9.25 AA.....GL-5[4]
All Temps......75W-90
Severe Gear 75W-90
SAE 75W-90 Synthetic Gear Lube
Severe Gear 75W-110
Differential, Front C205F.....GL-5
Severe Gear 75W-90
Severe Gear 75W-110
Differential, Rear 10.5 AA.....GL-5[4]
Severe Gear 75W-90
Severe Gear 75W-110
Differential, Rear 11.5 AA.....GL-5[4]
Severe Gear 75W-90
Severe Gear 75W-110
Controlled Slip Differential, Rear 9.25.....GL-5*[4][5]
All Temps......75W-140
Severe Gear 75W-140
Standard Differential, Rear 9.25.....GL-5[6]
Severe Gear 75W-140
SAE 80W-140 Synthetic Gear Lube
Transfer Case,.....AP4
Fluids
Power Steering Fluid.....AP4
Brake Fluid.....HB
Series 500 High Performance DOT 3 Brake Fluid
Clutch Fluid.....HB
1. SAE 5W-30 is preferred.
2. Mopar part no. 04874464.
3. Mopar part no. 4874459 (synthetic).
or Castrol Syntorq are recommended.
4. Synthetic based oil.
5. Trac-lok equipped axles require Limited Slip Additive be
added to the lubricant.
6. Synthetic based oil.
CHASSIS LUBRICATION
Two-wheel drive
6-9 Fittings, 0 Plugs..........LB
Series 2000 Synthetic Racing Grease
Synthetic GHD Heavy-Duty EP Grease
Synthetic Multi-Purpose Grease NLGI #2
Four-wheel drive
5-11 Fittings, 0 Plugs..........LB
CAPACITIES
Engine, with filter..........7.0 quarts[1]
Cooling System, Initial Fill..........19.0 quarts
AMSOIL Antifreeze and Engine Coolant'
Automatic Transmission, 48RE Initial Fill..........4.0 quarts[2]
Automatic Transmission, 545RFE 2WD Initial Fill..........5.5 quarts[2]
Automatic Transmission, 545RFE 4WD Initial Fill..........6.6 quarts[2]
Automatic Transmission, Total Fill
4 speed 48RE..........17.0 quarts
5 speed 545RFE 2WD..........17.0 quarts
5 speed 545RFE 4WD..........17.0 quarts
Manual Transmission, NV4500..........8.0 pints
Manual Transmission, NV5600..........9.5 pints
Manual Transmission, NV3500 4WD..........4.2 pints
Manual Transmission, NV3500 2WD..........4.9 pints
Differential, C205F Front..........3.4 pints
Differential, with 9.25"AA Front..........4.6 pints[3]
Differential, with 10.50 AA Rear..........4.6 pints[4]
Differential, with 11.50 AA Rear..........7.6 pints[5]
Differential, with 9.25 Rear..........4.9 pints[5]
Transfer Case,NV271..........4.0 pints
Transfer Case,NV273..........4.0 pints
Transfer Case,NV241 GENII..........3.4 pints
Transfer Case,NV243..........3.4 pints
Transfer Case,NV244 GENII..........3.4 pints
1. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all
gears. Check fluid level in NEUTRAL and add fluid
as needed.
3. Fill no higher then 1/4" below plug hole.
4. Fill no higher then 3/4" below plug hole.
5. Fill no higher then 1/4" below plug hole.
TORQUES
Oil Drain Plug.....25 ft-lbs
Transfer case
Fill Plug.....15-25 ft-lbs
Drain Plug.....15-25 ft-lbs
Manual Transmission NV3500
Fill Plug.....14-20 ft-lbs
Drain Plug.....14-20 ft-lbs
Manual Transmission NV5600 6-SPD
Fill Plug.....22 ft-lbs
Drain Plug.....30 ft-lbs
Manual Transmission NV4500
Fill Plug.....25-35 ft-lbs
Drain Plug.....25-35 ft-lbs
Trans Filter:58843
[1]
Trans Filter:58846
[2]
[1]
[3]
1.Twin Spark
2.Twin Spark
3.Twin Spark
4.Twin Spark
5.8 Lead Set
TRICO WIPER BLADES
T16240
EXACTFITT241
T241
WINTERT37245
T37245
OKTANE24 inch
24 inch
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
75W-85[3]
Severe Gear 75W-90
Severe Gear 75W-110
Severe Gear 75W-90
Severe Gear 75W-110
Severe Gear 75W-90
Severe Gear 75W-110
Severe Gear 75W-90
Severe Gear 75W-110
Severe Gear 75W-140
Severe Gear 75W-140
Fluids
Brake Fluid.....HB
Clutch Fluid.....HB
CHASSIS LUBRICATION
Two-wheel drive
Four-wheel drive
CAPACITIES
as needed.
TORQUES
Transfer case
Trending Topics
i tallyed it all up, for the amsoil its gonna be $300 with the tranny filter, and if i went a genaric brand it would be about 230, but i think its worth the extra $$, and how do i know what typ of tranny do i have? and wile were at it transfercase? its a dummy stick if that helps, didint know dodge had that many autos, its to my understanding the 48RE is for a diesel right?
