Name for the Pulley attached to the fan
Old Jan 6, 2009 | 12:32 PM
Ilovemytruck's Avatar
Ilovemytruck
Question Name for the Pulley attached to the fan
I found that problem, the pulley that attaches to this large shaft that connects to the fan is shaking like its having a seizure. I know that its supposed to move a little but its convulsing and I can see the belt moving off its path slightly. What is this pulleys name, is it the water pump pulley? And can I tighten this or do I need a new one?
Old Jan 6, 2009 | 02:16 PM
osufans's Avatar
osufans
I don't know about the Rams, but it used to be that pulley was the actual drive pulley. It is connected to the crank and that is what drives the belt and all accessories on the belt. Maybe a crank pulley?
Old Jan 6, 2009 | 04:14 PM
nim81's Avatar
nim81
on my 5.9L its the water pump pulley. and yes you will probably have to replace it.
Old Jan 6, 2009 | 05:18 PM
lxman1's Avatar
lxman1
Site Moderator
Water pump pulley. Replace the pump!!
Old Jan 6, 2009 | 06:03 PM
dirtydog's Avatar
dirtydog
Moderate User
Slow down a bit. Is the pulley tight? Did you check the bolts? The waterpump has a pulley bolted to it that the belt rests on. If the bolts came loose then just tighten up the bolts.
At first I was thinking of a fan clutch, but aint no belt touching the fan clutch in any kind of car, only the pulley that drives it.
Old Jan 6, 2009 | 06:17 PM
dodgeorgethit's Avatar
dodgeorgethit
If its attached to the fan its the water pump...or the fan clutch..
Old Jan 6, 2009 | 07:49 PM
Ilovemytruck
The pulley itself seemed fine; the fan sometimes has some play in it; only when I put the belt back on did i see the pulley start wobbling. The pulley wobbles like that when the belts on so like LX said Im thinking it's the water pump; The sound I posted on youtube was probably reverberating through the pully and fan clutch allowing the noise to be heard.
I sometimes notice my coolant temp fluctuates alot so Ive narrowed it down too; 1. Fan Clutch 2.Serpentine tensioner 3.Water Pump. I really dont believe the pulley itself went bad but the water pump inside thus causing the bad vibration!
Smash the hypothesis if you think Im wrong lol ill take any and all ideas before I go to the Stealer.
Old Jan 6, 2009 | 07:57 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
F it...shotgun troubleshoot that bish and just replace all three
Old Jan 7, 2009 | 12:32 AM
dodgeorgethit
lost one fan blade once...thought i blew the clutch(because it shook like crazy right after a shift)...limped it homeward..didn't quite make it..blew another blade right through the radiator...needless to say it wasn't the clutch..lol
Old Jan 7, 2009 | 10:11 AM
Ilovemytruck
what caused the blades to blow?
