Raising gas mileage?
Old Feb 24, 2009 | 08:13 PM
HammerZ71's Avatar
HammerZ71
Originally Posted by Off_Road_Teacher
Those are some serious power numbers for a gas tuner.
yeah, I think the exact numbers are like 46 HP and 59 TQ. Best numbers on any gas tuner I've ever seen. SC states when they got into writing a tune, they just found gobs of power DCX never took advantage of...
Old Feb 24, 2009 | 08:30 PM
blakeroberts88's Avatar
blakeroberts88
That just tells me DCX wanted to be lazy and not manufacture the engine to it's full potential. For the terrible gas mileage I would expect a much more powerful engine and with a tuner giving those kind of results I just get disappointed in Chrysler's engineers.
Old Feb 24, 2009 | 10:13 PM
lax's Avatar
lax
you know the single best mod out of all of them is?....(i know ill get yelled at for saying it).... lower it
Old Feb 25, 2009 | 08:13 AM
blakeroberts88
I agree, the lower you are the less drag you create. However, that reduces your ground clearance which good ground clearance is something I find very important in a truck.
Old Feb 25, 2009 | 10:48 AM
talon6's Avatar
talon6
mine is tuned up well. and i get about 11mpg with mods in my sig.mostly city driving though.(25 to 35mph)and around 12mpg is what most get. i did see 13mpg before. with the stock 20's and junk wrangler hp's.
and donnt believe those big numbers on the superchip for the 5.9. though it does run alot better, but somehow they have been exagerated. i would guess about 20-25hp. cause i can tell a difference performance wise compared to the hypertech max energy and jet stage 2 chip i had. just not that big of a difference.
Old Feb 25, 2009 | 11:06 AM
superdak05's Avatar
superdak05
drive slower and check tire pressure. look at what the door jam says for pressure, than look at the tires max pressure. try and get the pressure between the two numbers. if the jam says 35 psi and the tire says max 44 psi, get it in the middle 4o psi, this will help out some. and if your driving is mostly around town or stop and go traffic. a simple gear swap will do the trick, those trucks like 4.56 gears
Old Feb 25, 2009 | 12:50 PM
talon6's Avatar
talon6
i need 4.56's. they just keep getting moved farther down my list.lol
Old Feb 25, 2009 | 01:03 PM
bigpappaholt's Avatar
bigpappaholt
How does e-fan help?
Old Feb 25, 2009 | 02:17 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Those numbers that SC posts for that tuner are hard to believe. Have you used the 3815 on a 5.9?
Old Feb 25, 2009 | 02:26 PM
Off_Road_Teacher
It removes the parasitic loss associated with the clutch fan that comes stock on our trucks.
