Quick queston, 2008 Hemi Ram is 7 quarts of 5w20 right?
Old 03-06-2009, 12:43 PM
RamMan25's Avatar
RamMan25
RamMan25 is offline
Default Quick queston, 2008 Hemi Ram is 7 quarts of 5w20 right?
Im at work, leaving from work today to go buy my oil, I cant remember for the life of me if its 6 or 7 quarts, and if its 5w20.
Old 03-06-2009, 02:02 PM
06 Ram5.7's Avatar
06 Ram5.7
06 Ram5.7 is offline
Unless they changed it after 06, its 7 qts of 5w-20
Old 03-06-2009, 02:05 PM
BEAR's Avatar
BEAR
BEAR is offline
Might be a stupid question but is the owners manual in the truck? If it is look in it, but I think that 7qts of 5-20 is right. Also the grade of oil should be on the oil cap.
Old 03-06-2009, 02:48 PM
HEMI07's Avatar
HEMI07
HEMI07 is offline
yes thats right...just had my 07 done yesterday
Old 03-06-2009, 06:55 PM
V_Scapes's Avatar
V_Scapes
V_Scapes is offline
my 04 calls for 5w 30
Old 03-06-2009, 07:22 PM
sos's Avatar
sos
sos is offline
That's because your engine does not have MDS, which requires 5W-20 to operate correctly.
As others have said, 7 quarts of 5W-20 is correct.
Old 03-25-2009, 06:38 PM
dedogg's Avatar
dedogg
dedogg is offline
Question
with that being said if you disable the MDS do you need to switch?
Old 03-25-2009, 06:42 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
I used to think the same thing, that the only reason was the MDS, then it was pointed out to me that the '05, which is identical to the '04 in every way, specs 5w-20. WTF
Old 03-25-2009, 07:05 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Dodge Forum Moderator
That's normally because the bearing clearance is tighter on the newer models, but I'd say it's more for better mileage for the EPA and sales. The 5w-20 is what's spec'd out for the bearing clearance thickness. There is a whole science behind it, well, for the most part...lol
I run 5w-30 in my 08 Ram with the MDS turned off. Otherwise stick with the factory specs for oil.
Old 03-25-2009, 07:10 PM
donjohnk's Avatar
donjohnk
donjohnk is offline
I got the 05', no MDS and recommends 5w-20
Quick Reply: Quick queston, 2008 Hemi Ram is 7 quarts of 5w20 right?
