guess what I got!!!
Old Mar 8, 2009 | 04:57 PM
jonnymagnum's Avatar
jonnymagnum
Default guess what I got!!!
I got a CEL........
P0420 (M) 1/1 Catalytic Converter Efficiency Catalyst 1/1 efficiency below required level.
I'm gonna reset the code and see if it comes back...
Old Mar 8, 2009 | 05:03 PM
nim81's Avatar
nim81
get the hacksaw out and cut the cat off, replace with some pipe, do the non fouler trick with the o2 sensor, and cel gone and your truck will rumble!!
or seriously... you could have a bad o2 sensor or cat is getting clogged.
Old Mar 8, 2009 | 05:28 PM
moosefire66's Avatar
moosefire66
What is the non fouler trick with the o2 sensor?? I have never heard of this...
Old Mar 8, 2009 | 06:03 PM
nim81's Avatar
nim81
of you get rid of your cat, your o2 sensor will throw a cel.
the trick is to get a sparkplug nonfouler ( i used 2 on my durango connected together.
you screw in the nonfouler to the o2 bung and plug the o2 sensor into that.
what it does is takes the o2 sensor out of the flow of exhaust only letting the o2 read a lil bit of exhaust gasses. hence not dectecting the elevated levels of bad gasses or whatever.
Old Mar 8, 2009 | 06:43 PM
lxman1's Avatar
lxman1
Site Moderator
Usually a bad sensor is the culprit.
Old Mar 8, 2009 | 06:57 PM
jonnymagnum
ya tomorrow I'll clear the code. and if it comes back, I'll check out the 02 sensor. I know I replaced one of them last year.. but I forget which one lol
Old Mar 8, 2009 | 07:56 PM
HammerZ71's Avatar
HammerZ71
Go to the FAQ section, I did a DIY on it with pics, ages ago...
Old Mar 8, 2009 | 08:26 PM
Parts/Service's Avatar
Parts/Service
Originally Posted by jonnymagnum
I got a CEL........
There is a TSB on this issue. It involves replacing the downstream O2 sensor on the side giving you trouble.. In this case it would be the left side. And the TSB also states to Flash the PCM. The TSB number is 18-016-07. I cannot link to Chryslers TSB due to legal issues....
Old Mar 9, 2009 | 06:03 PM
jonnymagnum
so would that be a warranty thing then? or no. I remebered I replaced the upstreme sensor in the left side last year due to a code.. but I erased it and it hasnt came back yet. but I only drove it about 10 minutes home from the shop.. I"ll have to keep an eye on it
