C clip removal
Old Mar 19, 2009 | 01:23 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
Default C clip removal
So I'll have to take the axle shaft out to get to the E-brake. Any tips on how to get the c clip off? just wedge a screwdriver in there? Anything I should look out for?
Old Mar 19, 2009 | 02:13 PM
ramhunter9's Avatar
ramhunter9
they make a tool any auto shop has them like 5 bucks called a c-clip tool its a good tool to have because allot of things use c-clips i carry one in my tool bag for work . get one and enjoy....or you could use 2 screw drivers but could damage the clip
Old Mar 19, 2009 | 02:17 PM
04-fourseven's Avatar
04-fourseven
Like this?
http://www.etool.ca/RENDER/1/26/185/4560.html
Old Mar 19, 2009 | 02:47 PM
ramhunter9's Avatar
ramhunter9
yes sir!
Old Mar 19, 2009 | 03:11 PM
spedly's Avatar
spedly
Wrong type of c-clip. To get the c-lips off the axles in your truck you:
Remove diff cover and drain fluid
remove bolt securing cross pin to differential
remove cross pin
push axle in to diff from the wheel end(it will only move an inch or so)
take a magnet and pull clip off axle if it didn't fall off by itself when you pushed the axle in
now you can slide the axle completely out of the tube
Old Mar 19, 2009 | 04:20 PM
RubberFrog's Avatar
RubberFrog
What he said. It's pretty easy.
Old Mar 20, 2009 | 08:28 AM
xfeejayx's Avatar
xfeejayx
remove cross pin
so it just might fall off? it just gets wedged in there??
Old Mar 20, 2009 | 08:44 AM
spedly's Avatar
spedly
yes its not really a clip its just a round piece of metal with a slot cut in it
