troubleshooting advice
Old Mar 20, 2009 | 11:13 PM
johnschoenbeck's Avatar
johnschoenbeck
Default troubleshooting advice
got a 2003 ram hemi.. car will start. engine will turn over. run for about 2 or 3 seconds and then choke out. any advice
Old Mar 21, 2009 | 11:03 AM
MikeHTally's Avatar
MikeHTally
Water in the gas? REALLY dirty TB? Any codes?
Old Mar 21, 2009 | 01:53 PM
sos's Avatar
sos
I've had an issue on my old truck with similar symptoms in the past - check your battery terminals for corrosion. After not being able to figure it out on my own, I had to get it towed to a local garage. $200 later, that's what the whole problem was caused by. Next, I'd have your electrical system checked - if the battery is still good, if the alternator is giving out enough power, etc. I believe some of the auto parts stores will do this for free or a small charge.
Old Apr 1, 2009 | 10:23 PM
johnschoenbeck
codes came up for the crank sensor. i replaced the cam and crank sensor. i also replace the fuel pump assembly which includes the fuel filter and the fuel pressure regulator. still same problem
Old Apr 1, 2009 | 10:28 PM
matthewbeard's Avatar
matthewbeard
crap in the fuel lines?
Old Apr 1, 2009 | 10:55 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Pretty sure there's a re-learn procedure for those...star scan might be needed. Someone that knows for sure will chime in.
Old Apr 2, 2009 | 01:09 AM
04-fourseven's Avatar
04-fourseven
Did you try disconnecting the battery for a little while to see if it would re-learn itself?
Old Apr 2, 2009 | 08:28 AM
hemiyellow's Avatar
hemiyellow
DC Insider
if there are any re-learn procedures you'll need to go to the dealer....STARscan can't be used for the trucks till 2006 if i remember right so DRBIII will be needed........try unhooking the battery for 20 min or so and try starting it...see what codes you get to come back, if any.....
