Wind Noise Issue SOLVED
Old Sep 4, 2010 | 06:30 PM
  #21
lxman1's Avatar
lxman1
Site Moderator
My only noise comes from my vent visors. I drive the highway everyday
Old Sep 5, 2010 | 09:18 PM
  #22
weedahoe's Avatar
weedahoe
Hall of Fame Member
I had to replace the drivers side door seal on mine also as it was torn.
Old Sep 8, 2010 | 11:58 PM
  #23
ckapp's Avatar
ckapp
Looks like my wind noise is gone on the highway, glad i tried the door jamb first cause it was very easy to do. Granted i can hear faint, nearly inaudible wind noise but nothing like the torrent of air before the adjustment.
Old Sep 9, 2010 | 01:28 AM
  #24
nx75080's Avatar
nx75080
Ive worked in a body shop for years and "bending" the door is a common fix for alot of wind noises and water leaks.Where I work we actually call it the "GM shuffle" cause just about all the GM's made in the 90's had some sort of wind noise so we were always adjusting them.
For those that wonder about hurting the paint,your not actually bending the door,but "tweaking" it.Usually top right corner above window.You have a better chance of busting the window if you forget to put it down than the paint flaking.Manufacturers use a really good adhesion promoter in factory paint,so it will flex quite a ways before cracking,just like on plastic bumpers.
Most bodyshops will not charge or charge VERY little to do this to hopefully get your business next time you need something else done.
Old Sep 9, 2010 | 12:17 PM
  #25
bigmac18's Avatar
bigmac18
Originally Posted by rtmtrrdr
WOW! there is NO WAY i'd bend the door....I just adjusted the catch plate and guess what?....no more wind noise.And no bending of the door.
Same here...5 minutes of my time and it worked like a charm
Old Dec 26, 2010 | 02:43 PM
  #26
neil300zx's Avatar
neil300zx
Originally Posted by lstough
The designer of the hinge system should be fired, then shot. First there is no limit arm (like on most auto doors) to keep the door from bending the hinge outward when the door is forced opened beyond the limit the hinge itself will allow. When the door swings open hard, like when the wind catches it, the hinges bend away from the frame creating a new pivot point for the door. This is ever so slight but when extended to the top of the door it expands to about 1/4 inch. This in turn reduces the amount of pressure the door has on the rubber gasket causing air to leak in. When you take you Dodge to the dealer, they lie. The are very much aware of the design problem but will only adjust the strike system. Sometimes this helps slightly but is only temporary. Dodge wants you to go away and only come in with problems they can solve. It is suprising that since Dodge new about this problem from the begining, '04 model that they failed to fix it on future model. The service manager at Dodge did give me a tip on how to fix it myself which I tried and sure enough it worked. I read all the posts and suprisingly no one even thought of it. If you want the secret, Id be happy to share. Just contact me.
Why not just share it with everybody
Old Dec 26, 2010 | 04:09 PM
  #27
bigred177's Avatar
bigred177
Does anyone get any wind noise on their sliding rear window? I think that is where my noise is coming from. I don't ever have anyone riding with me to tell me, it's not the driver's door though.
Old Dec 27, 2010 | 11:47 AM
  #28
weedahoe's Avatar
weedahoe
Hall of Fame Member
They did come out with replacement door seals. There is a TSB on this. These in combination of properly installed and adjusted doors will keep any air leaks out. Now if your doors are bent from trying to wedge things in between them to unlock them if you locked your keys on the inside, well then they are bent or warped and thats another issue.
