Trans Gauge Install Questions
Old 05-09-2009 | 03:46 PM
SilverBullet08's Avatar
SilverBullet08
idk but i have the sender in the test port right now. it wasnt that hard. im making the wiring nice and neat too. taking a lot of pics lol
  #32
Old 05-09-2009 | 05:30 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Oh man, I am glad to hear that you are getting this thing installed. I can't wait to see it working for you. The pod looks damn good too.
  #33
Old 05-09-2009 | 05:58 PM
SilverBullet08
yea teach... man i thought the wiring on the hellas were hard lol
  #34
Old 05-09-2009 | 06:19 PM
SilverBullet08
It lights up!!! i think i have all my wiring right. the needle didnt move when i started the truck though. but i havent driven the truck since yesterday at 2 so its probably pretty cool., finishing up putting everything back together now and then taking it for a drive. will post pics later!!
  #35
Old 05-10-2009 | 01:28 AM
SilverBullet08
gauge is on and working...i think lol didnt get a chance to drive it lol
  #36
Old 05-10-2009 | 01:39 AM
AF_HEMI's Avatar
AF_HEMI
what the heck silver??? i been watchin this thread all day waitin for pics. when you finally posted again i got all excited!! ...then the let down.
  #37
Old 05-10-2009 | 01:47 AM
SilverBullet08
dude i have pics but was making diy. here are some teaser shots. i need to get night pics bc it lights up bad a$$
there are more pics so dont worry
  #38
Old 05-10-2009 | 02:30 AM
ramjamhemi's Avatar
ramjamhemi
I finished up my trans gauge install a week ago before towing a camping trailer from Phoenix to the Grand Canyon. I picked up a Mopar single pod A-pillar for $50 and a Glow Shift trans gauge for $20.
I connected the gauge ground it to an existing retaining screw that is under the drivers side dash access panel (directly under the A-pillar, and you can only get to it with the driver's door open).
I ran the power wire out the firewall, directly to the fuse box and used a fuse adapter. I didn't want to spend $10 for the "fancy" mini fuse adapter, so I bought the $.99 blade fuse adapters and trimmed it to fit. I added the adapter to a spare fuse socket along with a 3amp fuse. Covered the wire in convoluted tubing and used wire ties to secure it along the path back to the firewall.
I added a length of wire to the sensor wire and ran it out the firewall, over the back of the engine, and down to the passenger side of the transmission. Covered the sensor wire with convoluted tubing as well (10 feet for $5 was more than enough to do both the sensor wire and and hot wire to the fuse box) used wire ties to secure this one as well. Pay attention to keep it away from the exhaust pipe. Since Glow Shift does not make a short sensor like AutoMeter, and I wanted to put the sensor in the TCC Apply port on the passenger side of the transmission (as seen in response #21 of this post), I bought a 1/16 T fitting, 1/16 male to 1/16 male adapter, and a 1/16 plug. I also had to buy the Autometer 3280 1/8 to 1/16 adapter This combo allowed me to put the long sensor down into the T fitting. I was concerned that it would not register the temp well, but it seems to work fine. Fittings cost me about $5 at the local hardware store. I grounded the sensor to an existing engine ground that is right near this area of the trans. I did not want to break loose the factory nut for the ground so I just added another 10mm nut over the top of the existing stud and used an eyelet connector on the wire.
Finally I spliced the ignition positive wire into a wire I probed for under the dash.
I like to solder wires rather than using crimp connectors, so it took a little more effort to get this done. Laying upside down under the dash trying to soldier can be a pain.
Not counting the primary wire I already had on hand, this cost me about $81 before tax. The A-pillar was an Ebay deal, and the gauge itself from Craigslist.
  #39
Old 05-10-2009 | 03:39 AM
04-fourseven's Avatar
04-fourseven
Cant wait to see your gauge DIY silver! BTW, You saw the pics of my door handles; well I just finished my cowl! Looks good man, I will make a thread...
  #40
Old 05-10-2009 | 03:40 AM
AF_HEMI's Avatar
AF_HEMI
seems theres more than 1 way to skin a cat... i prefer whatever is easiest...not too concerned about spendin a few extra bucks to save some headache.
silver you're such a tease...
