had a BIG uh oh
Old Apr 21, 2009 | 05:20 PM
Horseapples's Avatar
Horseapples
Originally Posted by nathanp
good to know about the springs!! I will change my mind on those, im mainly wanting power for the street and towing, i have a handheld programmer. As for the stroker kit, im hoping i dont have to do the pistons or anything like that
Sorry to be the bearer of bad news, but it you broke a couple of valves, you wiped out a couple of pistons in the process. When the valve drops, it contacts the piston, then the piston, doin what a piston does, tries to compress the broken valve, the aluminum piston has no chance in this endevor and a hole in the piston or a valve embedded in the piston is the result.
Old Apr 21, 2009 | 05:22 PM
Horseapples
I would also be willing to bet you did some pretty serious damage to the cylinder head, the piston tends to beat the s*it out of the valve on anything available (head most often) Just pray you didnt trash the block!
Old Apr 21, 2009 | 07:01 PM
CarGuyOhio's Avatar
CarGuyOhio
Originally Posted by 02Steve1990
just curious, how many miles do you have on your truck?
I know where you are going. 2005 came with a 7/70 drive train warranty, which would cover this.
The 7/70 is standard if you bought the truck new. If you bought it used you would have had to transfer it, would have cost about $150.
Old Apr 21, 2009 | 07:14 PM
02Steve1990's Avatar
02Steve1990
True, I also figured the age of the truck mileage wise could have had something to do with this also
Old Apr 21, 2009 | 08:29 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Sounds like a great excuse to get a set of performance heads to go with that cam when you do the swap.
Old Apr 21, 2009 | 08:42 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
unfortunately, I agree. unless you got super lucky, dropped valves will take out a piston almost instantly.
really, you'll be lucky if the block doesn't need a rehone. i would expect the cylinder wall to be scuffed or scored.
Old Apr 22, 2009 | 02:21 PM
nathanp's Avatar
nathanp
ya when i said i hope i dont have to do pistons, i mean like ALL the pistons, im sure it wasnt every cylinder that dropped a valve or whatever. My machine shop said more then likely the cylinders that arent damaged wont need new pistons.
The truck has about 145,000 km on it, so its off warranty already for awhile now.
Old Apr 23, 2009 | 12:05 PM
nathanp's Avatar
nathanp
is it a big deal to change the retainers??? what would the difference between the 260 cam and the 268 cam? the 260 seems very hard to find. Would handheld programmer still be able to tune enough for the 268??
Old Apr 23, 2009 | 12:26 PM
Trigger's Avatar
Trigger
Let me guess you had the Hemi tick before this happened, didn't you? Welcome to the wonderful world of broken valves on the 5.7.....
Old Apr 23, 2009 | 12:31 PM
Alpheus's Avatar
Alpheus
WHAT!!! Almost all Hemis have a tick. Some start within a couple hundred miles of them being brand new. A hemi tick is no indication of impending doom. Get your facts straight...
