had a BIG uh oh
Old Apr 24, 2009 | 11:25 AM
  #31
nathanp's Avatar
nathanp
grrrr so the place i ordered the cam from, online siad they had 6 in stock and now they say they dont have any and are back ordered from comp cams and could be 6 to 8 weeks, so im gonna check out the krc ones
Old Apr 24, 2009 | 01:51 PM
  #32
nathanp's Avatar
nathanp
alright guys, so a little update, finally get everything ordered, and confirmed on its way, here is the list now:
- 6.1L Hemi Exhaust springs
- 6.1L Hemi 1 piece pushrods
- Comp Cams titanium Retainers
- KRC 218 Camshaft
- KRC sct custom tuner
now... just gotta wait for it all to get here, cam might take awhile so might have to install it myself down the road, i hope not though
Old May 19, 2009 | 02:15 PM
  #33
nathanp's Avatar
nathanp
anyone know whats needed to make a stroker?? just the crank?
Old May 19, 2009 | 04:12 PM
  #34
Hoss356's Avatar
Hoss356
If you go longer on the crank you have to go shorter on the rods.
Old May 19, 2009 | 06:11 PM
  #35
MikeHTally's Avatar
MikeHTally
Originally Posted by nathanp
Update #1:
They pulled the engine out, pulled the heads off, and cylinder #8 was empty.... rod, piston gone. The guy said that he has never seen a cylinder empty before, figures the rod snapped and the piston fell into the crank and exploded. So long story short this is what is now needed:
- cylinder bored and sleaved
- new connecting rod
- new piston
- new crankshaft
- new crank bearings,
- crank journals machined
this is ending up being more then i expected!
Maybe #8 was never there.
Old May 21, 2009 | 11:12 AM
  #36
nathanp's Avatar
nathanp
no i guess he said that the bearing wore out and then the connecting rod was rubbing on the crankshaft and the rod ceased to the crank, causing the rod to snap off, pretty big mess, im surprised it didnt bust a hole in the block.
Old May 21, 2009 | 11:45 AM
  #37
Horseapples's Avatar
Horseapples
Yep, you are lucky it didnt trash the block. You ought to have a sweet engine when its all done tho!
Old May 21, 2009 | 12:17 PM
  #38
nathanp's Avatar
nathanp
ya looked into making it a stroker, but i dont think i can afford that, 1200 bucks or so for the crank, then all new rods ontop of that. Oh well, it will be cammed up and stiffer valve train, should be good enough for me! Should wake up the bastard with the headers to.
Old May 21, 2009 | 01:35 PM
  #39
DodgeThunder's Avatar
DodgeThunder
Im surprised it didnt bust a hole in the block.
Yah your super lucky.. my buddy just hydrolocked his 08 ram with only 1500KMs on it last weekend and blew a chunk outa the passenger side of the block the size of a baseball!!
Old May 21, 2009 | 01:54 PM
  #40
nathanp's Avatar
nathanp
wow, ya i am lucky then!! thank the hemi gods i dont need a new block haha. I bet his is under warranty though!
