had a BIG uh oh
Old Apr 21, 2009 | 12:52 PM
nathanp's Avatar
nathanp
Default **Update**had a BIG uh oh
Was driving home on friday and heard a bunch of bangs and clangs and a huge cloud of smoke out the tailpipe... pulled over and shut the engine down right away. Well found out today that it was a couple snapped valves, they dont know how it happened or why it happened. So i guess its time for a small rebuild. In that case i went shopping today and this is what i picked up, since the engine is gonna be torn apart:
-Comp Cams 260/264 camshaft
-Comp Cams Valve Springs, Single, 1.055 in. Outside Diameter, 313 lbs./in. Rate, 1.085 in. Coil Bind Height, Set of 16
-Comp Cams Valve Spring Retainers, Titanium, 7 Degree, 1.055 in. Outside Diameter, Beehive, Chrysler, 5.7L, Set of 16
-Comp Cams Pushrods, Hi-Tech, Chromemoly, Heat-Treated, 5/16 in. Diameter, Mopar, Hemi V8, 5.7/6.1L, Set of 16
what you guys think??? Good combination of stuff?
Update #1:
They pulled the engine out, pulled the heads off, and cylinder #8 was empty.... rod, piston gone. The guy said that he has never seen a cylinder empty before, figures the rod snapped and the piston fell into the crank and exploded. So long story short this is what is now needed:
- cylinder bored and sleaved
- new connecting rod
- new piston
- new crankshaft
- new crank bearings,
- crank journals machined
this is ending up being more then i expected!
Old Apr 21, 2009 | 12:58 PM
RubberFrog's Avatar
RubberFrog
Lose the comp springs. Thay have a history of failure in the 5.7 with high lift cams. Get a set of 6.1 exhaust springs instead. It's just not worth the risk.
The 260 is a good torque camand does welll in qc's. Do you have a tuning solution for it? What are your plans for the truck? Street, strip, towing?
Old Apr 21, 2009 | 01:14 PM
Horseapples's Avatar
Horseapples
I agree with Froggy! 6.1L springs or Manley's. The 6.1's are much cheaper than either Comp or Manley
Since your going to be in there anyway... Why not get yourself a nice stroker kit?
Old Apr 21, 2009 | 01:48 PM
2005cobrakiller's Avatar
2005cobrakiller
6.1's is the way to go homey total agreement here... doesn't really matter what you do if u run the **** out of ur truck like i do it will break like mine always is but we have fun dont we GG
Old Apr 21, 2009 | 02:09 PM
nathanp's Avatar
nathanp
good to know about the springs!! I will change my mind on those, im mainly wanting power for the street and towing, i have a handheld programmer. As for the stroker kit, im hoping i dont have to do the pistons or anything like that
Old Apr 21, 2009 | 02:12 PM
nathanp's Avatar
nathanp
when u say 6.1L exhasut springs, does that mean like use the exhaust springs for the intake to??? Or do u get the 6.1L exhaust aprings AND the 6.1L Intake springs
Old Apr 21, 2009 | 02:29 PM
RubberFrog's Avatar
RubberFrog
Use exhaust springs for both. Sounds weird, but it works and they'll be bullet proof with that cam.
Old Apr 21, 2009 | 02:35 PM
HammerZ71's Avatar
HammerZ71
yeah, the comp beehives have a poor reputation, supposedly they are fixed now. Manley's have an awesome reputation, but so do the 6.1s at a fraction of the cost. Good move to go to the 6.1s...
That's a decent low end torque cam, you should like it. Decent gains while not needing a custom tune. You should be happy with that setup...
Old Apr 21, 2009 | 02:40 PM
TRXHemi's Avatar
TRXHemi
It was so important, Hammer said it twice!! LOL Let us know how it runs when all if rebuilt.
Old Apr 21, 2009 | 03:15 PM
02Steve1990's Avatar
02Steve1990
just curious, how many miles do you have on your truck?
