new guy on the block
#22
You have to pull the storage tray in the back, and I think you have to pull the torx bolt holding the bottom of the seat belt and then lift up the trim that runs under the door when it is closed. Pull the top part loose above the speaker and then work the lower one loose. Then you have to work the rest of the trim off where the speaker is b/c it has the metal clips that just pop in and out. Take your time b/c these directions are just from memory and there could be some things I'm forgetting.
#23
