Regular cab sub box
Regular cab sub box
I need to add some boom to my truck. I already have 2 Kicker 12" CVR's which have a mounting depth of 6-5/16" and are calling for a minimum of 1 cubic foot of air space in a sealed box. I found a prefab box but it is not deep enough to fit the subs. I am trying to make a custom box to fit in the tray behind the seat and I think I have figured it out but the box does not have enough air space. I am going to add some polyfil which tricks the subs into thinking there is more airspace than there really is. I was just wondering if anyone else has solved this problem. I use my truck as a truck so no ideas like pass throughs or the armrest box. What have you done and pics would be helpful. Thanks.
The best way to get the desired air space in a regular cab is to remove the tray, and build a box that sits on the floor.
Here's a link to what mine is kinda going to look like.
http://www.pickupspecialties.com/Sub..._dodge_ram.htm
Bottom left of the page
http://www.subthump.com/dodgeram.htm
Hemi44, I have seen that box (the only prefab for a dodge regular cab) but the problem with that is it doesn't have the right mounting depth. I was thinking about a shop doing a custom fab fiberglass box but then its alot more expensive than buying a sheet of 3/4" MDF and its far more rewarding to make your own box. Since I am going off to college in the fall, I also wanted to keep as much space in the cab as I can. I am being really picky becuase I do want to keep the tray in and as much space as I can. I also want it to look custom but not be obvious when you look in my window in a parking lot. I think I have figured it out though. I should be making the box toninght or tomorrow and when I finish I will put up some pics. The diminsions are 16" high in the back, 15.5" wide, 8" high in the front, 11.5" deep, and an angled board at the top.
Trending Topics
Hontzy, that box looks pretty sweet. Did you spray paint the fosgate logo on there? I did think about the spacers but wasnt sure if it would seal up correctly. I think I have figured out the design I am going to use. It gives me .82 cubic feet of air space and then I will add some polyfill which tricks the sub. Do you know how thick the wood is in that prefab box?
