Cleaned throttle body now issues
Alright I cleaned my throttle body today. Disconnected the sensors. Did I have to physically remove the sensors from the body. Since that's the problem then. Truck is shifting erratically and seems to be reading the throttle body position wrong. Am I right with it being the Position Sensor? Or did I mess up something else now?
Anyone? I took the sensor off made sure the hole on the throttle body was free of any junk and put the sensor back in. Seems to have improved shifting a tad but its still a bit off. And the RPM randomly jumps up while driving also. Could the MAP sensor or any of the others have anything to do with this? I'm planning to go get a new sensor in the morning. Just hoping I have the right one.
carb. Could any of the other sensors be causing this problem? Or do I definitely have it narrowed down to the TPS? I've heard bad things about carb cleaner then I've heard things that say its fine. So I used it. Also it seems better now but I still have the occasional jump in RPM and delayed shifting even though its less noticeable now.
Trending Topics
If your going to replace the TPS you could try:
https://dodgeforum.com/forum/2nd-gen...ensor-fix.html
I thought I'd throw the throttle body one in as well eventhough you've already done the throttle body.
https://dodgeforum.com/forum/2nd-gen...ttle-body.html
Alright I took it out before for a few minutes drove up the expressway a bit hit like 65-70 and stuff. It's still a bit delayed with shifting. I'm taking a nice trip in the morning. Maybe with some traffic and open road. So ill report back after that. If still issues ill pick up a TPS. I checked the tps thread before. For 35-45 bucks ill pick up one. I don't want the same problem again.
