2003 4.7, any other motor bolt right in?
Old Jul 10, 2009 | 04:36 PM
ryan42080's Avatar
ryan42080
Default 2003 4.7, any other motor bolt right in?
i have an 2003 dodge ram with a 4.7... starting to have engine problems, and curious if any other motors will drop in without changing wire harness or moving engine mounts???
Old Jul 10, 2009 | 04:38 PM
dirtydog's Avatar
dirtydog
Moderate User
Uhhh, no. And, there's a bit of re-programming to be done as well.
Old Jul 11, 2009 | 09:48 AM
ryan42080's Avatar
ryan42080
re-programming or changing the computer is ovious, i just don't want to have to change out the wire harnness
Old Jul 11, 2009 | 12:54 PM
dirtydog's Avatar
dirtydog
Moderate User
You will have to swap harnesses as well as a few other engine components. the exhaust is differnt and yes the motor mounts are different. I believe the radiator is different as well. not sure if the trans bellhousings are the same either???
I'm not saying it can't be done, but it's a bit of work and time and there's the know how to factor.
ECU doesn't need to be changed, just flashed.
Old Jul 11, 2009 | 01:28 PM
Blown287's Avatar
Blown287
I know you are asking for a direct replacment, not exactly what your looking for but....There is a member on dak-dur who transplanted a Hemi into his dakota to replace his 4.7l. He had to modify the oil pan, replace the wiring harness etc, but he got it work and has helped others do the same.
http://www.dakota-durango.com/forum/...light=hemi+dak
Old Jul 11, 2009 | 07:18 PM
ryan42080's Avatar
ryan42080
thanks guys! think i'll just trade it in.
Old Jul 11, 2009 | 07:38 PM
lxman1's Avatar
lxman1
Site Moderator
Be cheaper to put a hopped up 4.7 back in it wouldn't it?
Old Jul 12, 2009 | 10:32 AM
superdak05's Avatar
superdak05
get intouch with jasper engines and have one delivered to the house, adirect replacement for around 1500 cant go wrong with that
Old Jul 13, 2009 | 11:33 PM
ryan42080's Avatar
ryan42080
i went to jasper's webstie they quoted me over $4000...
