fan and shroud diameter
I am asking a favor. Anyone with an 03 1500 w/4.7L, could you measure the diameter of the engine fan and the inside diameter of the fan shroud at the point where the fan goes in? I believe the Hemi trucks will be the same as well and maybe 03+ trucks. I am looking for these dimensions for a e-fan I want to install in the factory shroud ... I am offshore and not near my truck for awhile.
thanks for any help or comment,
rovman - louisiana
rovman - louisiana
I made some brackets and mounted the fan right to the radiator. Then I put the stock shroud back on over the new e-fan.
Check out the link below to the DIY. Should have all the info you need. I even think ORT created the DIY.
https://dodgeforum.com/forum/3rd-gen...c-fan-diy.html
Trending Topics
That DIY pretty much sums up everything I did to install mine. To answer your question about the controller, I am running this controller :http://moesperformance.com/index.php...oducts_id=1658
I am finally home from offshore:
ORT - I have planned on the flex-a-lite controller. Do you have the radiator temp probe or the NPT water probe? I do not see in the descrip what the cut-off temp is for the vari-controller ... any info?
By the by: I measured my fan blade, 19" ... the shroud opening is 22". I am now thinking of the 18" perma-cool with the flexalite vari-speed controller.
rovman
rovman
rovman
rovman
