rear noise
Old Aug 6, 2009 | 11:20 PM
mcgoo89's Avatar
mcgoo89
Default rear noise
i have anoise coming from the back 2 wheels. its whines and squeeks when driving but when i hit the brakes, the noise stops. i originally thought it was the wheel bearings, but i dont think it would sound like that. the noise gets lower the faster i go. any suggestions?
Old Aug 8, 2009 | 02:53 AM
mcgoo89's Avatar
mcgoo89
anyone have a clue?
Old Aug 8, 2009 | 07:49 AM
BEAR's Avatar
BEAR
Have you taken the rear wheels off and inspected your brakes? I would take a good look at them, your problem will probably be obvious.
Old Aug 8, 2009 | 08:31 AM
HammerZ71's Avatar
HammerZ71
You got the stock LSD?
Old Aug 8, 2009 | 03:58 PM
mcgoo89's Avatar
mcgoo89
My breaks are definately bad in the back, but wouldn't the squeeking be there when I hit the breaks? It squeeks all the time until I do hit the breaks and it stops. Yes I do have the stock lsd
Old Aug 8, 2009 | 04:05 PM
draco8494's Avatar
draco8494
well it doesent allways squeak when you hit the brakes, ide get the brakes changed first, and go from there, also the stock lsd is a poor design and often causes damage inside the rear end, im sure someone els will chime in on that tho
Old Aug 8, 2009 | 04:07 PM
Pyro's Avatar
Pyro
I Beat Tetris
Pop your diff cover off, check your gears and LSD, have a look see if there are metal shaving in the bottom. That noise could be a failing LSD.
Old Aug 9, 2009 | 01:51 AM
lxman1's Avatar
lxman1
Site Moderator
Worn pads will often squeak until you put pressure on them by pushing the pedal.
